Do USB Audio Cables Make A Difference?
Julf
Amsterdam, The Netherlands
It's not about the bits. It's about the clocking and how RFI impacts the analog stages of the converter.
Clocking is pretty much a non-issue with modern DACs with ASRCs (and asynchronous USB).
Bob Olhsson
True. IF there is an audible difference, it's about clocking and/or RFI.
Certainly, there shouldn't be differences caused by any cables, digital or analog, but manufacturers and their designers screw up.
solderdude
The Neitherlands
In any half decent design what goes on in the digital part should not have any consequences in the analog plane. Power supply management and PCB layout is important.
ribonucleic
I purchased a BlueJeans USB cable. I asked them for test data and they replied this is the ONLY cable they do not MAKE and source overseas and could not provide ANY information at all on build, wire etc.
You can tell they take a lot of pride in this offering.
jim1274
I could not resist adding that my recent purchase of a $2000 Benchmark DAC3 came bundled with a USB cable, just happening to notice it was a Monoprice cable. I think that is a $4 cable.
Says volumes.
IAtaman
Says volumes.
If it says volumes, why do you think it's monoprice? :facepalm:
Jimster480
Tampa Bay
Says volumes.
What do you mean? That cable is more than fine...
