- Joined
- Aug 5, 2021
- Messages
- 513
- Likes
- 543
Over the years I have seen some of my most significant advances in audio quality for my systems just by reading the instructions and making the correct connection/configuration (that was wrong to start with).....
I don't know about you guys but I am a typical user who leaves the instructions in the box unless it just does not work....not ideal for someone who likes to eek out every possible improvement from a system hey.
Example 1 - Using the Toslink optical return from my TV for audio path before using the proper HDMI connection direct into my AVR. Immediately gave me a very noticable lift in audio quality.
Example 2 - Discovering (after not too long mind you), that my sub was not turning on as I had the "on" trigger set to low sensitivity.
I could go on....
So now I actually re-read the instructions for my kit to check if there is anything I have missed or anything that may have changed in my system that may need additional configuration or settings.
I could go on....
