Does anyone know "How to calculate a EQ score ?"
reficver
Like the title, is there a program where I can see which EQ I applied and which score this makes a difference?
I sometimes post scores when I see people posting EQ information.
And sometimes the EQ applied by others is calculated as a score instead.
I want to do this myself.
alex-z
If you have the spinorama data, you can import that into VituixCAD, which has a preference rating display. You can then apply EQ filters in the crossover section and it will show in the preference score.
VituixCAD also has the auto-optimizer feature, which can be used to develop EQ that maximizes the preference rating.
R
reficver
Thanks for reply.
The program you mentioned looks good.
Then where can I get the spinorama data?
What Amir provides for each thread looks like a Txt file. (CEA2034, SPL, Vertical ...etc)
I tried to load this txt file into the program, but it seems to have a different extension.
baron-samedi
Hi,
Thanks for reply.
Hi, everyone. I would like to do this also. Anyone?
