Does Audyssey XT32 normalise gains?
CapMan
London
Would anybody happen to know if XT32 normalises gains to avoid applying EQ filters which boost. In other words does it drop the whole level down so the hightest boost is effectively at 0dB.
I ask because the filters being applied to my mains (as reported in 'check results' on the Audyssey menu of the AVR) have some significant boosts of more than 6dB around 120 - 200Hz. I have a suck out in the room at this frequency which Audyssey seems to be filling in.
When I used to do the EQ manually with REW I used my dual subs, XOd at 120Hz to partially fill in that suck out.
I am only using small sealed Bookshelf speakers and don't want to overdrive them
Any thoughts welcome.
peng
In some cases it would apply boost, up to a point but I forgot what the limit is, probably around 6 dB max, going by memory (vaguely). It wouldn't boost much, if at all, if it knows it is not going to work. Like Dirac Live, it leverage cuts, not boost.
