Does DSD sound better than PCM?
Status
Not open for further replies.
Purité Audio
Industry Insider
Barrowmaster
London
PCM is perfectly adequate, DSD was a flawed medium thirty years ago, nothing has changed.
Ron Texas
Most DSD had to go through a PCM stage for mixing and the like because only minimal adjustments can be made to DSD.
Blumlein 88
for music listening , if you convert PCM to DSD, do you get better sound?
There are those who claim that. If it were true, it would indicate DSD has a coloration that some people prefer. Like some people prefer vinyl even though it lacks fidelity vs PCM.
Often there is a sound level difference between the output of the same file in PCM vs DSD. If you take that into account, I would expect DSD not to sound different in most cases.
As for editing referred to above, you pretty much can't edit or process a DSD file other than in very simple ways. So production of DSD usually involves converting to DXD which is PCM at 352.8 khz 24 bit. Doing your editing in DXD, and then converting it back to DSD.
You could download and listen to various versions here:
http://www.2l.no/hires/index.html?
If you ask me, the answer is no you don't get better sound just using DSD.
Imagine if I digitally record (either with DSD or PCM) an old cassette tape. Either will accurately represent the tape, but the sound quality won't be improved just because I record it in a different medium.
watchnerd
Seattle Area, USA
Do you get better sound?
I am so confused.
If I use Roon in "exclusive mode" to listen to DSD natively, it sounds better to me than non-exclusive-mode DSD-to-PCM conversion.
I don't know if that's a consequence of the format, the conversion, or the mode.
Thomas savage
The Watchman
uk, taunton
Every single SACD I have with a PCM layer I prefer the PCM . The DSD sounds rolled off somehow and just dull but who knows if they are the same masters , I could just be disliking ‘audiophile ‘ mastering .
Imo DSD is epic bullshit.
Thomas savage
The Watchman
uk, taunton
That’s intresting , could we capture the signal and have a look at what the difference might be ?
watchnerd
Seattle Area, USA
By converting the analog back to digital? That would be PCM.
Or maybe my ADI can record in DSD, never tried -- either way, there is a "different format" question.
Blumlein 88
Listening to the analog output if it sounds different something is different. Seems a PCM recording of that analog result would give you a chance to see what it is. It may or may not work, but would be worth looking into I think.
Thomas savage
The Watchman
uk, taunton
Don’t bring me problems, bring me solutions damn it..
watchnerd
Seattle Area, USA
Trying to think if I can do that without creating a feedback loop in the ADI...
The 'stupid simple' option would be to unplug the XLR outs to the monitors on one side and plug it back into the analog inputs, but in analog world, that's feedback city....
D
dragonspit4
then why do audiophile want to use DSD? they claim DSD sounds better.
watchnerd
Seattle Area, USA
then why do audiophile want to use foo? they claim foo sounds better.
FIFY
where foo = USB scrubbers, "audiophile" USB or ethernet cables, cryogenically treated cables, demagnetizers, CD stoplight green pens, TICE audio clocks, AC power scrubbers, Mpingo disks, harmonic resonators, etc, etc.
Blumlein 88
You can do one channel at a time by feeding left output back into right input. No feedback. Then reverse for other channel.
graz_lag
Le Mans, France
Status
