GabrielPhoto
- Joined
- Jul 14, 2020
- Messages
- 402
- Likes
- 217
Hello,
I have been researching to upgrade my atmos speakers and within limitations it seems outdoor speakers will be the easiest option to replace my Polk OWM3 as they normally have a threaded insert which makes it a quick swap.
But something about outdoor speakers does not make me feel right so I started considering the PBS P3 but then I was reminded again of the Ascend 200SE:
My concern on that one is that if I am reading the vertical dispersion correctly, I am looking at about 15% which at a distance of 6.5' or so from MLP it doesnt look like it would give me a very wide "good sound" area. Or maybe is not that bad after all?
I am assuming this speaker will sound much better than something like the HTD Q65 outdoor speaker or an OSD AP650.
Am I interpreting things right?
HTM-200SE HOME THEATER MONITOR PAIR
High Performance Compact Speaker "The new 200SE continues the Ascend tradition of offering unmatched component quality and performance at affordable pricing." With a linear frequency response and bass down to 70Hz, this compact versatile loudspeaker is the perfect solution for space limited...
ascendacoustics.com
