Douk VU2 Review (VU Meter/Input Selector)
testp
They say, do what is expected from you. This one goes beyond... :)
jtwrace
Orlando, FL
Well, this is how you can use those single ended RCA outputs on your balanced DAC.
V
That's kinda what I was thinking for those that love lights and stuff. Just use it as a VU to show to your buddies who like that $hit.
Personally, the darker and less lights the better. :)
Johannes AU
Hongkong
This is the first cassette recorder (SONY TC-D5M) I owned before with very nice VU meters, still miss it.....
Rick Sykora
Stow, Ohio USA
I struggled to find a picture of the inside of the unit. This was the best I could find. Plenty of relays!
This is a VU3 and the review unit is a VU2. Am evaluating the VU3 for a customer. It is a speaker switch and the VUs get their signal from it. This pic is not from a golden sample btw, the boards are as clean as I have ever seen and parts designations are well done too.
Rick Sykora
Stow, Ohio USA
Might be working without distortion only from low-impedance sources like output of the power amplifier. Don't you have one somewhere to try it?
Had a comparable experience with the Douk VU3 until I put a dummy speaker load on the outputs. I was measuring frequency response, but now thinking I should try a distortion test too…
enricoclaudio
Houston, TX - USA
My VU Meter looks cooler and does not degrade the signal ;)
Nango
D:\EU\GER\Rheinhessen
I hope for the donor he gets this item back soon enough to return it to the vendor, what a crap, Sinad at 54 with no valves inside??? Amazing poor performance!! Get two rare extreamly rare NOS tubes involved and Sinad around 20 and will still be good enough for Darko to promote it!!!!
nagster
This is a review and detailed measurements of the Little Bear / Douk VU2 input selector and VU meter. It was kindly purchased new by a member and drop shipped to me. VU2 costs US $189 from Amazon including Prime shipping.
The main attraction here are the VU meters and Douk delivers with two large sized ones:
When turned on it lights up with the standard yellow glow. Alas, it only lights up the middle third and nothing like the uniform yellow their advertising shows. A horizontal bulb that covers 1/4 of the meter provides lighting with no diffuser (it is diffused itself).
The rear labeling is confusing:
How could one channel be in, and the other out? Then I realized it is bi-directional and can form 4 to 1 or 1 to 4. At least I think that is how it works.
More confusing are the front panel controls. They do NOT operate on the signal itself but the action of the meter. Delay is not delay but filtering of the VU meter. All the way to the left is "fast" and to the right, slow. I say "fast" in quotation mark because typical of these meters, it is slow to begin with. Still, nice to have the control.
The gain control is again for the meters. This is essential in my view to get reasonable movement out of them. And nicely so, there is AGC (automatic gain control) so it can optimize the movement for you.
In use, I found the Gain control and output to be quite erratic. At some settings of gain the meter with a steady signal would jitter back and forth. Strangely, even the green LED above it would do the same! The gain setting was also not linear. I got most of the range from minimum to just hair above. Then the output would strangely drop. I could not make any sense out of it.
In case you are wondering, that USB connection is for power. They give you a USB cable but no power supply. At this price, I expect one included. I used a high power one I have for RPi computer boards.
Little Bear Douk VU2 Measurements
I treated the unit like a pre-amp and fed it 2 volts and got this:
Oh boy. I expected a simple pass through link so did not at all expect distortion let alone at this very high level.
I suspected that the input stage of this thing is loading down the AP. So I put the AP in loopback mode meaning it is measuring itself. With nothing connected to AP, I would get SINAD of 121 dB+. But the moment I connected the output of the AP to VU2, I got this:
In other words, the VU2 is severely loading down the AP output causing such significant amount of distortion!
So not only can't you use this as a switcher, but you can't use a wired connection to sample your audio as that distorts that source. Maybe you have a buffered output in your pre-amp or something but if you don't, watch out.
Fortunately this thing also has a Microphone that can sample the audio that way. I did not measure this but just turning it on and tapping on it and such, it seemed to produce a movement on the VU meter.
Conclusion
Ah, what a missed opportunity to build a decent VU meter. :( I remember building a blinking disco light to the tune of music when I was 10 years old and it too distorted the heck out of the input when connected. I was concerned that this thing would do the same and it does. Its input needs to be buffered and high impedance to avoid this.
Sadly, as much as I love VU meters, I can't recommend the Douk VU2. It is just too broken.
I thought this was a good post.
Such cases are sometimes seen regardless of home or professional facility.
However, there are many people who do not care (do not know).
Additional parallel connections to the line should be done with caution.
Tom C
Wisconsin, USA
What a disappointment! This item is a rare find. It’s really a shame it’s so poorly implemented. I guess you could just put it on the desk and use the mike. Or just not connect it.
m8o
Meters are kewl, but ... WTF?!!!
What a face-palm moment. Now we can't even trust a component we'd all be forgiven for thinking is a zero-impact monitor + passive relay switch box.
Brings new meaning to the observer effect / Heisenberg uncertainty principle.
Dogen
Durham, NC USA
Great idea for a product but horrible implementation! I don’t know how something so simple could screw up the sound so much. That’s some kind of engineering.
enricoclaudio
Houston, TX - USA
I know that's a Raspberry Display but what software are you running on it that shows the VU meter? I have a Raspberry Display running RoPieeeXL and use it as remote with Roon.
