Eirikur
- Joined
- Jul 9, 2019
- Messages
- 318
- Likes
- 510
As already posted and (briefly) discussed on another thread, DR measurements of CDs versus vinyl records can be misleading, as convincingly demonstrated by Ian Shepherd using his own work
Ian further investigated what might cause the difference in DR
He continues to elaborate with some conjecture
OK, so far I'm just condensing Ian's findings.
Something I and many others already noticed is that many CDs from the 80s have much "better" numbers in the DR loudness database compared to most if not all remixes/remasters, for example one that I happen to own
From this you might easily conclude that the original 1986 CD is miles ahead of all the remasters... but is it?
As it turns out, this CD was mastered with pre-emphasis applied, meaning that proper playback would require applying de-emphasis.
As an avid user of foobar2000 I installed a component to do just that.
Next I made a comparison, both with DR and ReplayGain to see the difference (sit down or hold on to something)
What we can clearly see is that although the CUE sheet properly states
Thoughts and elaborations are appreciated!
In the video, I mention that I can hear a change in the image. More specifically, I hear it as narrower, on the vinyl. This is quite normal - there is always a certain amount of cross-talk between the left and right channels, and it's also quite common for the cutting engineer to choose to narrow the stereo image in the bass region, or even overall, as I mentioned above. I have no idea if that was done in this case - the image on the CD is quite wide, so it's perfectly possible.
Either way, I tried the same thing on the digital file, i.e. narrowing the stereo image slightly. And lo and behold, the measured DR value increased to... DR12! Looking very similar on the meter to what we see on the vinyl.
Now to the really important partSo, it may be as simple as that. Either a tweak during the cut, or just normal cross-talk, is sufficient to alter the wave-forms so that their peak level increases enough to account for the "extra" DR points.
And before anybody asks, no this isn't a "real" increase in dynamics, it's just a side-effect of the audio processing.
The channel cross-talk I mentioned will certainly play some part in what we're seeing, even if the engineer also made a tweak. And it happens on every vinyl release, and just like the EQ, it depends on the playback system.
In other words, the same record played on different decks may exhibit a different degree of image width, and measure a different DR value as a result - which is a point that's been made several times in this thread already. What's interesting to me is that this change alone is sufficient to cause the spurious DR boost, and it will happen to some extent whenever a piece of vinyl is played.
FLAGS PRE
for all tracks, it is not applied when calculating DR or ReplayGain. This sheds a new light on the entire DR database in my view.Thoughts and elaborations are appreciated!
