Andysu
- Joined
- Dec 7, 2019
- Messages
- 2,996
- Likes
- 1,558
trust no water mr. mulder .
i hear they putting way more alright chlorine or what ever else in the water . a neighbor convinced me . i got TDS to test the water and was shocked , shocked at the amount . after doing some destiller tests as got run the first few though the destiller to get the pipes filtered i guess ? once finished and tested water with TDS , wow i saw low numbers between 004 , 002 , way better than the 270 .
there is a taste difference with tap water and destiller water that tastes nicer .
so now i and my cats will be drinking destiller water .
process takes 4 hrs to turn the water into heat vapor that is filtered to fill the container . i get second container one filled with water cooled in the fridge and when getting low , due some more destiller , cleansing the water . also the TDS when testing the water after its been processed is hot will show a slightly higher TDS number 010 so and when once cooled in the fridge tested then shows lower TDS number of around 002 , it show 000 . theoretically .
