DSP for my Topping Stack?
jevchance
Hi everyone,
I recently moved from a vintage Marantz receiver to a Topping PA5/E50 stack. I know, right? I'm driving some Eosone RSF1000 speakers and the sound is extremely clean.
That being said, the speakers are not exactly flat, and my room leaves a lot to be desired. Plus I prefer a little bit of bass and treble boost. To that end, I'd like to add a DSP but I'm not sure what I could use that's compatible with the E50 and PA5. My source is a HEOS Link HS2 streamer. I'm currently feeding the E50 via optical.
Edit: my big concern is the balanced connection between the DAC and the amp. I don't want to disturb this clean chain.
Would appreciate any feedback on the topic. Thanks.
envydd
you can try the Minidsp flex digital when it’s out. Or just go for the minidsp balanced which also accepts an optical in and drive the pa5. I just got the same flex for my chromecast audio streaming.
Snoopy
Or just use roon
MCH
J
jevchance
Thanks everyone for the feedback. Looks like the minidsp is a winner. Need to save up some pennies!
FuzzTone
Hi everyone,
digitalfrost
Palatinate, Germany
What sources are you using? It's not like the E50 has a ton of inputs. If you use a PC, you can EQ for free.
J
jevchance
My source is a HEOS Link HS2. Currently its outputting optical to the E50, the E50 is balanced to the PA5.
