DT1770/DT1990 or Amiron?
Noodles
Netherlands
FR is only half the picture. I've only heard the dt770 and no there are no piercing S there but the treble was a bit much for me.
1770 were very shouty, could be my amp at the time (AAA 789).
If you can - go try them in a shop. Alternatively get them from a place that you can return with no issues.
D
Deleted member 22273
Guest
Good advice. People complain on bright grados. For me they sound warm and engaging
solderdude
The Neitherlands
When you can't hear sibilance on the DT770 nor Grado's you probably won't hear it on the DT1770 either.
Some folks aren't bothered by the peaks.
D
Guest
Usually listen to rock/folk/country.not so bright music
Noodles
Netherlands
Lower model Grados are actually quite fine. Yours are right at the crossing point into brighter Grados. Usually SR225-325 is the point above which they become quite ... much.
What i've found with my limited Grado experience (admittedly i do not like them for the build) is that the lower the model the more listenable they are. SR80 is probably the most balanced of the bunch.
Noodles
Netherlands
If you are fixated on Beyers, i think either the 1990 or Amiron is what you would be looking for. Leaning towards Amiron.
If you have an amp that has >50ohm output impedance - you should also check the 600ohm Beyer DT880
D
Guest
Fixed on beyer cause I own dt770(buyed 2017) and t51i(buyed 2014).sounds great, good built.will probely last for decades.
in 2016 i buyed BW P7, both drivers broke. repair on warranty. then sold. tryed Meze 99 C for 2 months ago. sound like shit and poor build quality. not assembled very well. loose parts. returnd to dealer.
so if i buy beyer again.,know it is good stuff.
but people says also HD-650/6XX is good
D
Guest
have about 1ohm output impedance. (schiit magni 3)
solderdude
The Neitherlands
solderdude
The Neitherlands
Just make sure you can return it and get your money back.
The ssss's can be cured without sacrificing clarity/tonality if needed.
If you can also try to audition (with possibility to return) the HD650 or HD560S that may be a good thing to make up your own mind.
D
Guest
had a short visit today at my local hifi shop.
they only had amiron.
took a quick look.
build ok. quality plastic.
bright? not at all. a lot of bass. not too much like meze 99.
but a lot more than 225e and dt770.dragonfly red was not powerful. they should have somthing more powerful.
think i can like them.
Noodles
Netherlands
They are a nice pick, dragonfly won't be able to drive them as they are 250 ohm, but your magni will do a good job.
D
Guest
first the guy give me a ipad mini.first i tought this was for remote.
but no.ask if he has somthing more powerful. he gave me the dragonfly.better. but he also have a rega io. I don't mentioned that.the io should probly drive it well.
this is a hifi store
D
Guest
not sure if amiron is my taste. too much clubsound.
another dealer can sell me a pair of grado ps500 for almost half prise.like new
