Dutch&Dutch 8C and 8M arrive next week!
Purité Audio
Industry Insider
Barrowmaster
London
Purité Audio have a new delivery of 8Cs arriving next week and D&Ds 8M, the 8Cs younger brother!
http://dutchdutch.com/
oivavoi
Oslo, Norway
Very interesting discussion on Gearslutz, btw, where the main engineer at Dutch & Dutch explains some of the design choices: https://www.gearslutz.com/board/mastering-forum/1187968-new-speakers.html
What I've been wondering, Keith: Does the software inside the 8Cs allow for making additional room correction in the bass, if you do measurements with an external mic? Dutch & Dutch don't write anything on it in the presentation, as far as I can see. If they can room correction algorithms, then these would really be an amazing all-in-one solution: Even Roon ready soon, which means that there would be no need for ANY additional boxes in my case. Pretty cool.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Thanks for that link, I hadn’t realised Martijn had posted on that thread.
Yes they have built in EQ which is configurable from the app, you can also increase and decrease the bass and treble , set the boundary distances from the side and front walls, adjust input gain, everything oh integrate subwoofers .
They are good ,
Soniclife
Where is the documentation on their control software? I can find nothing about it, what platforms it runs on, where to download it, what it does etc.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
It is just a page address, ‘ lanspeaker.com ‘ there are various versions, you need to connect some loudspeakers to open the app.
Soniclife
So it runs on anything with a browser, very flexible.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Very and soon Roon ready, you will be able to stream directly to them.
Soniclife
Will that require two lan cables, or do they communicate with each other?
Wombat
Australia
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
A cable to each speaker to set parameters , then a cable between speakers once set, you can include as many speakers as you like into a ‘group’.
I use mine with an RME ADI-2 to send digital to the 8Cs and attenuate .
Just to be clear the 8c's don't have a built-in ethernet switch. They're only endpoints. So if you want to be able to remote control them over the ethernet or stream to them, they both need a cable.
