- Joined
- Jan 15, 2020
- Messages
- 6,907
- Likes
- 16,972
1st electric order, we are talking about total acoustic order.Nope. Look at the crossover, its a 1st order with impedance compensation.
Also correct, although with a coaxial driver it could have been approximated more.AND, the linear-phase result is only achievable/measurable at a single point in space.
Nope. A first order crossover step response never looks like the S40 have. 1st order xo not even have one single sharp negative swing in the step at any point in space, even if it's phase aligned with additional elements in the crossover.Nope. Look at the crossover, its a 1st order with impedance compensation.
The reason for the step response is they are linearizing the phase response with precision filters or they designed the woofer to match the bode plot of the filter they already designed.
Yes but speaking only of actual acoustic roll off. Is it not possible to achieve 4th order acoustic roll-off or close to it, with a filter that is 1st electrically. Granted the natural driver roll of would have to be very, very optimal. I do believe that tweeter is claimed to have such properties.But the other guy is incorrect in that the SP40s are a "typical 2-way, 4th order step response". If you look at the picture of the crossover, it's enough to know its not 4th order. And looking at a step response is not decisive in determining the crossover topology.
Well, there are quite a few passive designs that cross 25-29mm tweets below 2k. I mean it is not uncommon at all. (not counting compression drivers which easily cross here and lower)It's insanity. Tweeters simply cannot absorb or dissipate the power/heat at those frequencies and at any decent levels. Not just dynamic compression you'll be dealing with, but cooked/vaporized VCs.
The electrical order of a crossover doesn't mean too much in itself. For example, you can have a 1st order electrical filter that produces 4th order acoustical slopes if combined so with the raw inbox responses of the drivers.But the other guy is incorrect in that the SP40s are a "typical 2-way, 4th order step response". If you look at the picture of the crossover, it's enough to know its not 4th order. And looking at a step response is not decisive in determining the crossover topology.
To add a little to what the others have already said....But the other guy is incorrect in that the SP40s are a "typical 2-way, 4th order step response". If you look at the picture of the crossover, it's enough to know its not 4th order. And looking at a step response is not decisive in determining the crossover topology.
I have indeed expressed willingness to test this mod. I even offered to pay to ship it back. Seeing how Danny makes his entire case using measurements, it is so odd that he doesn't want me to verify his work.Would be cool to see, but you'd probably be without them for a while, risk damage in shipping (probably the most likely) and I doubt Danny's going to want to risk being put underground by the NFS.
It is the only logical conclusion. Seeing how I am donating the time and effort to test his product with no profit motive, whereas he has one, it doesn't put his answer and conduct in good light.He probably doesn't want you to reveal his "upgrades" are a waste of money and make the speaker worse.
too many people have distorted value propositions here in which they wish every component to be dirt cheap and have the best measurements. People I hang out with have different priorities.
