E1DA 9038D Review (portable DAC & Amp)
This is a review and detailed measurements of the E1DA 9038D portable DAC and headphone dongle (US $99). It was kindly sent to me the company and forum member, @IVX. Sadly it has been sitting here for months until I got a chance to review it now. If you don't know about @IVX, he was the first one to break the laws of physics and produce a high power headphone dongle using balanced output. Seeing how he was self-thought in designing this dongle, it was a remarkable thing. But not everyone has a headphone with balanced wiring so here comes the 9038D in unbalanced configuration:
Connectivity is as you can expect with USB-C and 3.5mm jack:
I was very thankful to have a driver for the 9038D. Without it, the class driver in Windows exposes a 16 bit interface to my audio analyzer interface causing artifacts. As such, I usually run a subset of my tests with these dongles. In this case, I did manage to run all of my tests. I did run into an issue though which I don't know if it has to do with the driver or not. If I pause music in my Roon player, after 15 seconds or so, the device seems to power down as I hear some clicking and then low level static as if a capacitor is draining. It does recover when you hit play again so not a major inconvenience but it is there.
There is a second problem in that full amplitude digital signal causes mild clipping of samples. I saw that company specs it at -0.5 dB so I am assuming designer is aware of this issue.
E1DA 9038D Measurements (DAC)
Treating the device as a straight DAC, I ran my normal suite of tests:
Note again that I am testing at -.05 dBFS. At full amplitude performance drops to 88 dB or so. At 0.5 dBFS, performance is excellent for any DAC, let alone a small one:
Output level is 2.7 volts which means we will have good power to drive high impedance headphones.
Dynamic range at full output is excellent for a dongle and a bit above average at 50 mv output:
DAC reconstruction filter performance is an exception in a good way:
It is one of a handful of DACs that has a sharp enough filter to properly cut off out of band "images." I wonder though if this sharp filter has enough overshoot to cause the clipping we see at 0 dBFS.
Sweeping for output voltage we see the clipping point:
IMD test shows excellent performance with essentially no sign of "ESS IMD hump:"
Linearity was superb showing high accuracy:
Jitter test shows fair bit of unwanted tones but that is because the noise floor is very low. What is there is definitely not audible:
Multitone performance is superb:
As a side thing, people keep thinking that my tests are "simple" sine wave and that music waveforms are more complex. Here is the time domain (i.e. what the samples look like) of the multitone signal:
Doesn't look simple to me. Does it to you?
E1DA 9038D Measurements (Headphone Amp)
Power is everything in headphone amps so let's see how much we have at 300 ohm:
Compared to $9 dongles, this is a lot of power:
Balanced devices though beat it because they can go up to 4 volts output. Tables get turned though when we use a low impedance load and rely on current delivery:
E1DA 9038D Listening Tests
I used my usual Ether CX and Sennheiser HD-650 headphones (low and high impedance respectively). Performance was excellent with both. I was able to go to max power and get plenty of volume with no sign of distortion. Detail, bass performance, etc. was all up there. You can't go deaf using this dongle so desktop products produce even more power but what is here is plenty for on-the-go usage.
Given the pedigree of 9038D, I expected excellent performance and that is what I got. Two functionality bugs with 0 dBFS clipping and power down kept me from giving it the highest honors. I am hoping one is driver issue and/or is resolved by now.
As is, I am happy to give a recommendation to E1DA 9038D.
pozz
Слава Україні
Editor
@IVX Все закричали: "Браво!" ;)
Matias
São Paulo, Brazil
Why measured and ranked in 2.7 Vrms and not the "ASR standard" 2.0 Vrms?
Jimbob54
Outstanding @IVX . Glad to own one.
Jimbob54
Good point. Nice to know it performs well at this level but yes, 2V output also would be nice to see.
Matias
São Paulo, Brazil
It is there in the voltage versus SINAD graph, 1 dB less SINAD or so, but still it was strange seeing the dashboard out of ASR standards. Or maybe I am just nit picking and must drink more alcohol. :)
Jimbob54
I have drunk more and didn't see it. So no, let's both retire from this thread before showing our arses.
staticV3
For those interested, one of the coolest features is an Android App which controls DAC parameters directly.
The free version can set a hardware volume limiter (e.g. '-27.5dB') for sensitive IEMs or for high sensitivity Amps. It is saved between disconnects and applied no matter what source device you use.
The App can also turn on/off the standby mode that Amir was talking about.
And it can control the 9038D's hardware volume in .5dB steps.
The Pro version costs $10 currently and has a lot of extra features:
  • minimum volume limiter
  • Harmonic Distortion compensation:
    The 9038Q2M chip is able to generate 2nd and 3rd harmonics. This THD compensation can be set in three different zones, depending on the DAC's current hardware volume. All changes happen in real time (see here). With it, you can:
    • increase distortion to simulate your favorite tube amp, or:
    • with the right measurement equipment, introduce phase-inverted harmonics at the same level as the DAC's natural harmonics for a given load, effectively cancelling them out. Here's the result of that:
  • MCLK control:
    You can define the DAC's MCLK for each supported sample rate. Higher MCLK will reduce noise, but will introduce more high-order harmonics.
  • Reconstruction/Nyquist/Oversampling filter control:
    Similar to the MCLK, for each of the supported sample rates, you can choose between 8 different filters.
  • Presets:
    You can save all your settings as presets, share them with others, as well as choose from a number of official presets.
All changes you make in the App happen in real-time, and can be done while playing music, which makes choosing a filter for example a lot easier.
An iOS version is impossible due to Apple's USB restrictions.
The App is called Tweak9038.
Vini darko
Dorset England
    • with the right measurement equipment, introduce phase-inverted harmonics at the same level of the DAC's natural harmonics for a given load, effectively cancelling them out. Here's the result of that:
  • MCLK control:
    You can define the DAC's MCLK for each supported sample rate. Higfher MCLK will reduce noise, but will introduce more high-order harmonics.
  • Presets:
That's a cool list of fuctions on a dongle
Tks
Pretty nice, though I'm surprised there's regressions in the 50mV spec and also the odd channel balance being a bit off (would have imagined this wouldn't be a thing).
I also appreciate the SINAD stability throughout the power range when usually you see lower levels on other DACs perfoming far worse than max output. Peak power is also massive (a single ended dongle pulling through beyond 2V spec is really something to behold).
Btw @amirm did you measure THD+N Ratio vs Frequency, or thermal metrics since this thing will be in all sorts of environmental settings I imagine?
sam_adams
Check in the Device Manager under USB devices to see if any of the root hub devices or other attached USB devices has a Power Management tab under its properties. If it does, there should be a 'Enable selective suspend' checkbox there. Uncheck it.
Rottmannash
Nashville
I just ordered one earlier this week. Glad to know it's gonna sound great.
MC_RME
That is exactly what I need. Max output level +9.3 dBu even at 33 Ohms load. 7 dB more oomph compared to US iPhones, more than 10 dB compared to castrated EU iphones. Which throws up the question: how do I use it with an iPhone and its Lightning connector? And if there is a matching cable, will there be enough current available? iPhones 11 Pro owner here.
sam_adams
You'd need something like this. However, the iPhone may not be able to supply the required current to power the device. You'd have to test it yourself for suitability for your needs.
