E1DA Cosmos APU - Teardown and personal thoughts and measurements
Rja4000
Liège, Belgium
I also request somebody state in a few simple sentences what this does. It's not an auxiliary power unit, nor accelerated processing unit. Analog processing unit. A microphone amp, but more?
This is a measurement device, very specialized for 1kHz (or 10kHz) THD (Sinad) measurement.
Basically, the issue with measuring SINAD of a device (DAC, Analog,...) is the limitations of your ADC.
You need the ADC to have a performance at least 10dB better, for peace of mind, than the device under test (DUT).
And this is where the problem is: with current DAC or headphones amp performance, you can't find a pure ADC that has this level of performance. The RME ADI-2 Pro ADC, a market reference, remains around 117-119dB SINAD. The E1DA ADC, using a new ESS ADC chip, is a bit better.
But none of them can reliably measure a DAC/amp with over 120dB SINAD.
You can't say if what you measure is the DAC/amp or the ADC.
THD and SINAD are usually measured by comparing the noise+ distortion to the signal. The signal being at 1kHz and with a level near the maximum capacity of the DUT.
So, what the traditional analyzers do is to notch out the 1kHz (remove the 1kHz peak, using a very steep and narrow analog band-cut filter), and amplify what remains BEFORE the ADC, bringing the DUT's remaining noise and distortion within the ADC measurement capability range.
And then the software computes the real values.
This is what Amir's AudioPrecision analyzer does.
The APU does the same.
And, since it's using some more recent chips, and also since it's only doing this for 2 fixed frequencies, the APU actualy outperforms somehow the AP for a signal level around 1V-5V.
EDIT: To make it clear:
In my opinion, the APU is the most useful innovation for amateur audio measurements in the last 3 years.
Or, maybe, even since the release of the RME ADI-2 Pro.
Rja4000
Liège, Belgium
As a complement, one may want to read the comments I made with this measurement, performed with the APU
AudioSceptic
Northampton, UK
maybe, however, Cosmos ADC has a gain range 1.7-10Vrms so you have an additional 15db to adjust it ;) 34db and 60db is compromising between 3 different tasks:
a) DACs, amps, LDOs noise measurement.
Example:
AES17 Dynamic Range test performs at -60dbfs level by measuring the THD+N A-weighted. That plot shows the residual THD+N (A) of the LNA at 1-10mV level sweep. 2mV corresponds 2V 0dbfs DAC like CS43131, and -82db needs to subtract 60db to get AES17 DR = 142db(BTW, 10x better than APx555b). A typical high-performance DAC with 5Vrms 0dbfs could be measured down to 150db and so on.
b) vinyl ripping with 34db of the gain for a MM cartridge, and 60db for the MC. Cosmos ADC has internal DSP where is implemented RIAA+subsonic filter.
Example:
Cosmos APU+Cosmos ADC+RIAA.
MM case, 5mV 10ohm source APU gain 34db Cosmos ADC 1.7V sensitivity, THD+N -89db or -97.7db(A). Due to H2 and H3 being very low, SNR is also 97db(A).View attachment 232916
MC case, 250uV 10ohm source APU gain 60db Cosmos ADC 1.7V sensitivity, THD+N -66db or -78db(A). Due to H2 and H3 being lower than the noise floor, SNR is also 78db(A).
c) microphones usage.
Example:
The gain of Cosmos APU preamp is +60db(1000x times), hence the scale units are nVrms(A). After the APU unit turns On, you can see 5s of settling,
from 6s the input noise reaches 130nV, about 9s 48V power was turned On, and after 1s reached 142nS. Hence, APU's phantom power adds just 12nV to the preamp noise, that's a nearly ideal result as I think ;) The test was performed with a shorted preamp's inputs(In+ to In-) and biased to the GND by 2x6.8kOhm resistor as a dummy condenser mic.
I apologise for these stupid questions. The Cosmos ADC can apply RIAA for vinyl but needs the APU to provide enough gain (34 dB for MM, 60 dB for MC), so I could use the 2 together to feed into a DAC for playing instead of ripping? Did you consider adding an RIAA option to the APU so it could act as a phono preamp on its own, or would this not make any sense?
AudioSceptic
Northampton, UK
Guys, this is tech stuff, you don't need that if have no plan to measure distortions, noise, or a dynamic range at finer levels than $30K Audio Precision analyzers do. Also, this is the tool(preamp) for ripping vinyl by the most "digital" approach(I may miss something but Cosmos ADC+APU combo is the unique offer on the market today), or this preamp may work as a good studio mic preamp with built-in high-quality 48VDC phantom power.
That's it.
But if the APU is mono, we would need 2 to rip vinyl in stereo?
Reactions: pma
AudioSceptic
Northampton, UK
This is was Amir's AudioPrecision analyzer does.
And when doing a sweep, the Audio Precision has a sliding notch filter to match?
Reactions: pma
pma
Prague
If you want to do it in one go, then yes. Alternatively you can record L and R separately and realign in post.
From vinyl?? You will get plenty of random errors between 2 separate vinyl runs and rips. This suggestion is not good, from technical point of view.
Rja4000
Liège, Belgium
The AP, as far as I understood, is using various methods, according to the measurement you do.
As an example, it, of course, doesn't use an analog notch to perform multitone measurements... Only the ADC.
So I don't know for the "sweep" (what exactly do you refer by that ?),
but I expect that the THD vs frequency uses, indeed, a variable frequency notch filter.
I might be wrong though.
It also uses a mix of analog generator and DAC generator.
About AP, you may ask Amir or our fellow @SIY, who wrote a review of the APx555B in AudioXPress some time ago
IVX
South of China, SHZ area, - Слава Україні
I did try that with Quartz PLL turntable, at least at one track it is Ok. But, of course, I did that because I had only one single APU on my hands at those time.
AudioSceptic
Northampton, UK
I tried ripping vinyl, but it was so tedious that I decided to not bother again and just get the albums on CD (or just play the vinyl if there was no CD version). Doing L & R separately would multiply the tedium beyond the limits of my sanity.
AudioSceptic
Northampton, UK
I meant a frequency sweep, such as the usual 20 Hz - 20 kHz.
