Earfonia IEM Measurement Setup & Methodology
ObjectAudio
The way I am doing it is finding the T2P resonance frequency by fitting the IEM in my ears the way I will use them to listen to music, and then using frequency sweep generator to find it. After that I am inserting the IEM into the IEC711 coupler with depth that will generate the same resonance frequency. The resulting frequency response is used to equalize to my target.
Earfonia
Earfonia
Singapore
Oh that's a pretty cool approach! I never thought of that before. What software of frequency generator that you use? I wish to have frequency generator that the frequency can be adjusted with mouse scroll. REW generator doesn't work with mouse scroll so it is very inconvenient to adjust the frequency using keyboard. I don't have hardware frequency generator. That would be nice to be able to adjust the frequency using hardware know.
taudier
I think the ER2XR would be better with a hole in the shell behind the speaker :)
markanini
Scania
If you don't mind me piggybacking. In a similar spirit, here I've found a point where manufacturer tuning, and data-driven work done by Sean Olive and Oratory1990, intersect. I could have thrown in Moondrop KXXX in there too. The target curve I've overlayed was produced by averaging USound target and Harman 2019 target above 750Hz, below 750Hz Harman 2019 is discarded.
Blorg
Would it be possible to get a text file of this target, that does look very good.
markanini
Scania
Sure.
Code:
* Measurement data measured by REW V5.19
* Source: Trace Arithmetic result (A + B) / 2
* Format: Trace Arithmetic result (A + B) / 2
* Dated: Dec 24, 2022 4:07:36 PM
* REW Settings:
*  C-weighting compensation: Off
*  Target level: 75.0 dB
* Note: USound lows & 5050 highs
* Measurement: A,B average
* Smoothing: None
* Frequency Step: 1/96 octave
* Start Frequency: 20.0 Hz
* Freq(Hz), SPL(dB), Phase(degrees)
20.000, 9.033, 0
20.145, 9.033, 0
20.291, 9.033, 0
20.438, 9.033, 0
20.586, 9.033, 0
20.735, 9.033, 0
20.885, 9.032, 0
21.037, 9.032, 0
21.189, 9.032, 0
21.343, 9.032, 0
21.497, 9.032, 0
21.653, 9.032, 0
21.810, 9.032, 0
21.968, 9.032, 0
22.127, 9.031, 0
22.288, 9.031, 0
22.449, 9.031, 0
22.612, 9.031, 0
22.776, 9.031, 0
22.941, 9.031, 0
23.107, 9.030, 0
23.274, 9.030, 0
23.443, 9.030, 0
23.613, 9.030, 0
23.784, 9.030, 0
23.956, 9.030, 0
24.130, 9.029, 0
24.305, 9.029, 0
24.481, 9.029, 0
24.658, 9.029, 0
24.837, 9.029, 0
25.017, 9.028, 0
25.198, 9.028, 0
25.381, 9.028, 0
25.565, 9.028, 0
25.750, 9.027, 0
25.937, 9.027, 0
26.125, 9.027, 0
26.314, 9.027, 0
26.505, 9.026, 0
26.697, 9.026, 0
26.890, 9.026, 0
27.085, 9.025, 0
27.281, 9.025, 0
27.479, 9.025, 0
27.678, 9.024, 0
27.879, 9.024, 0
28.081, 9.024, 0
28.284, 9.023, 0
28.489, 9.023, 0
28.696, 9.023, 0
28.904, 9.022, 0
29.113, 9.022, 0
29.324, 9.021, 0
29.537, 9.021, 0
29.751, 9.021, 0
29.966, 9.020, 0
30.183, 9.020, 0
30.402, 9.019, 0
30.622, 9.019, 0
30.844, 9.018, 0
31.068, 9.018, 0
31.293, 9.017, 0
31.520, 9.017, 0
31.748, 9.016, 0
31.978, 9.016, 0
32.210, 9.015, 0
32.443, 9.014, 0
32.678, 9.014, 0
32.915, 9.013, 0
33.154, 9.013, 0
33.394, 9.012, 0
33.636, 9.011, 0
33.880, 9.010, 0
34.125, 9.010, 0
34.372, 9.009, 0
34.621, 9.008, 0
34.872, 9.007, 0
35.125, 9.007, 0
35.380, 9.006, 0
35.636, 9.005, 0
35.894, 9.004, 0
36.154, 9.003, 0
36.416, 9.002, 0
36.680, 9.001, 0
36.946, 9.000, 0
37.214, 8.999, 0
37.483, 8.998, 0
37.755, 8.997, 0
38.029, 8.996, 0
38.304, 8.995, 0
38.582, 8.994, 0
38.861, 8.993, 0
39.143, 8.992, 0
39.427, 8.990, 0
39.712, 8.989, 0
40.000, 8.988, 0
40.290, 8.987, 0
40.582, 8.985, 0
40.876, 8.984, 0
41.172, 8.982, 0
41.470, 8.981, 0
41.771, 8.979, 0
42.074, 8.978, 0
42.379, 8.976, 0
42.686, 8.974, 0
42.995, 8.973, 0
43.306, 8.971, 0
43.620, 8.969, 0
43.936, 8.967, 0
44.255, 8.965, 0
44.575, 8.963, 0
44.898, 8.961, 0
45.224, 8.959, 0
45.552, 8.957, 0
45.882, 8.955, 0
46.214, 8.953, 0
46.549, 8.950, 0
46.886, 8.948, 0
47.226, 8.946, 0
47.568, 8.943, 0
47.913, 8.940, 0
48.260, 8.938, 0
48.610, 8.935, 0
48.962, 8.932, 0
49.317, 8.929, 0
49.674, 8.926, 0
50.034, 8.923, 0
50.397, 8.920, 0
50.762, 8.917, 0
51.130, 8.914, 0
51.500, 8.910, 0
51.874, 8.907, 0
52.249, 8.903, 0
52.628, 8.900, 0
53.009, 8.896, 0
53.394, 8.892, 0
53.781, 8.888, 0
54.170, 8.884, 0
54.563, 8.880, 0
54.958, 8.875, 0
55.356, 8.871, 0
55.758, 8.867, 0
56.162, 8.862, 0
56.569, 8.857, 0
56.978, 8.852, 0
57.391, 8.847, 0
57.807, 8.842, 0
58.226, 8.836, 0
58.648, 8.831, 0
59.073, 8.825, 0
59.501, 8.820, 0
59.932, 8.814, 0
60.367, 8.808, 0
60.804, 8.801, 0
61.245, 8.795, 0
61.688, 8.788, 0
62.135, 8.781, 0
62.586, 8.775, 0
63.039, 8.767, 0
63.496, 8.760, 0
63.956, 8.752, 0
64.420, 8.745, 0
64.886, 8.737, 0
65.357, 8.729, 0
65.830, 8.720, 0
66.307, 8.712, 0
66.788, 8.703, 0
67.272, 8.694, 0
67.759, 8.685, 0
68.250, 8.675, 0
68.745, 8.665, 0
69.243, 8.655, 0
69.745, 8.645, 0
70.250, 8.635, 0
70.759, 8.624, 0
71.272, 8.613, 0
71.788, 8.601, 0
72.309, 8.590, 0
72.833, 8.578, 0
73.360, 8.566, 0
73.892, 8.553, 0
74.427, 8.540, 0
74.967, 8.527, 0
75.510, 8.514, 0
76.057, 8.500, 0
76.608, 8.486, 0
77.163, 8.471, 0
77.723, 8.456, 0
78.286, 8.441, 0
78.853, 8.426, 0
79.424, 8.410, 0
80.000, 8.393, 0
80.580, 8.376, 0
81.164, 8.359, 0
81.752, 8.342, 0
82.344, 8.324, 0
82.941, 8.306, 0
83.542, 8.287, 0
84.147, 8.267, 0
84.757, 8.248, 0
85.371, 8.228, 0
85.990, 8.207, 0
86.613, 8.186, 0
87.241, 8.165, 0
87.873, 8.143, 0
88.510, 8.120, 0
89.151, 8.097, 0
89.797, 8.074, 0
90.448, 8.050, 0
91.103, 8.025, 0
91.763, 8.000, 0
92.428, 7.975, 0
93.098, 7.949, 0
93.773, 7.922, 0
94.452, 7.895, 0
95.137, 7.867, 0
95.826, 7.839, 0
96.520, 7.810, 0
97.220, 7.781, 0
97.924, 7.751, 0
98.634, 7.720, 0
99.349, 7.689, 0
100.069, 7.658, 0
100.794, 7.625, 0
101.524, 7.592, 0
102.260, 7.559, 0
103.001, 7.525, 0
103.747, 7.490, 0
104.499, 7.455, 0
105.256, 7.419, 0
106.019, 7.382, 0
106.787, 7.345, 0
107.561, 7.307, 0
108.340, 7.269, 0
109.126, 7.230, 0
109.916, 7.190, 0
110.713, 7.150, 0
111.515, 7.109, 0
112.323, 7.067, 0
113.137, 7.025, 0
113.957, 6.982, 0
114.783, 6.939, 0
115.614, 6.894, 0
116.452, 6.850, 0
117.296, 6.804, 0
118.146, 6.758, 0
119.002, 6.712, 0
119.865, 6.665, 0
120.733, 6.617, 0
121.608, 6.569, 0
122.489, 6.520, 0
123.377, 6.470, 0
124.271, 6.420, 0
125.171, 6.369, 0
126.078, 6.318, 0
126.992, 6.266, 0
127.912, 6.214, 0
128.839, 6.161, 0
129.773, 6.108, 0
130.713, 6.054, 0
131.660, 5.999, 0
132.615, 5.944, 0
133.575, 5.889, 0
134.543, 5.833, 0
135.518, 5.777, 0
136.500, 5.720, 0
137.490, 5.662, 0
138.486, 5.605, 0
139.489, 5.547, 0
140.500, 5.488, 0
141.518, 5.429, 0
142.544, 5.370, 0
143.577, 5.311, 0
144.617, 5.251, 0
145.665, 5.190, 0
146.721, 5.130, 0
147.784, 5.069, 0
148.855, 5.008, 0
149.933, 4.947, 0
151.020, 4.885, 0
152.114, 4.823, 0
153.217, 4.762, 0
154.327, 4.699, 0
155.445, 4.637, 0
156.572, 4.575, 0
157.706, 4.512, 0
158.849, 4.449, 0
160.000, 4.387, 0
161.159, 4.324, 0
162.327, 4.261, 0
163.504, 4.198, 0
164.688, 4.135, 0
165.882, 4.072, 0
167.084, 4.010, 0
168.295, 3.947, 0
169.514, 3.884, 0
170.742, 3.821, 0
171.980, 3.759, 0
173.226, 3.696, 0
174.481, 3.634, 0
175.746, 3.572, 0
177.019, 3.510, 0
178.302, 3.448, 0
179.594, 3.387, 0
180.895, 3.326, 0
182.206, 3.265, 0
183.527, 3.204, 0
184.856, 3.143, 0
186.196, 3.083, 0
187.545, 3.024, 0
188.904, 2.964, 0
190.273, 2.905, 0
191.652, 2.846, 0
193.041, 2.788, 0
194.440, 2.730, 0
195.849, 2.672, 0
197.268, 2.615, 0
198.697, 2.559, 0
200.137, 2.503, 0
201.587, 2.447, 0
203.048, 2.392, 0
204.520, 2.337, 0
206.002, 2.283, 0
207.494, 2.229, 0
208.998, 2.176, 0
210.512, 2.123, 0
212.038, 2.071, 0
213.574, 2.020, 0
215.122, 1.969, 0
216.681, 1.919, 0
218.251, 1.869, 0
219.833, 1.820, 0
221.426, 1.772, 0
223.030, 1.724, 0
224.646, 1.677, 0
226.274, 1.630, 0
227.914, 1.584, 0
229.565, 1.539, 0
231.229, 1.494, 0
232.905, 1.450, 0
234.592, 1.407, 0
236.292, 1.364, 0
238.004, 1.322, 0
239.729, 1.281, 0
241.466, 1.240, 0
243.216, 1.200, 0
244.979, 1.161, 0
246.754, 1.122, 0
248.542, 1.084, 0
250.343, 1.047, 0
252.157, 1.010, 0
253.984, 0.974, 0
255.825, 0.938, 0
257.678, 0.904, 0
259.546, 0.870, 0
261.426, 0.837, 0
263.321, 0.804, 0
265.229, 0.772, 0
267.151, 0.740, 0
269.087, 0.710, 0
271.037, 0.680, 0
273.001, 0.650, 0
274.979, 0.621, 0
276.972, 0.593, 0
278.979, 0.566, 0
281.000, 0.539, 0
283.037, 0.513, 0
285.088, 0.487, 0
287.153, 0.462, 0
289.234, 0.438, 0
291.330, 0.414, 0
293.441, 0.391, 0
295.568, 0.368, 0
297.710, 0.346, 0
299.867, 0.324, 0
302.040, 0.304, 0
304.228, 0.283, 0
306.433, 0.263, 0
308.654, 0.244, 0
310.890, 0.225, 0
313.143, 0.207, 0
315.412, 0.190, 0
317.698, 0.173, 0
320.000, 0.156, 0
322.319, 0.140, 0
324.655, 0.124, 0
327.007, 0.109, 0
329.377, 0.095, 0
331.764, 0.081, 0
334.168, 0.067, 0
336.589, 0.054, 0
339.028, 0.041, 0
341.485, 0.029, 0
343.959, 0.017, 0
346.452, 0.006, 0
348.962, -0.005, 0
351.491, -0.015, 0
354.038, -0.025, 0
356.604, -0.035, 0
359.188, -0.044, 0
361.791, -0.053, 0
364.412, -0.061, 0
367.053, -0.069, 0
369.713, -0.077, 0
372.392, -0.084, 0
375.090, -0.091, 0
377.809, -0.097, 0
380.546, -0.104, 0
383.304, -0.109, 0
386.081, -0.115, 0
388.879, -0.120, 0
391.697, -0.124, 0
394.536, -0.129, 0
397.395, -0.133, 0
400.274, -0.137, 0
403.175, -0.140, 0
406.096, -0.143, 0
409.039, -0.146, 0
412.003, -0.148, 0
414.989, -0.150, 0
417.996, -0.152, 0
421.025, -0.154, 0
424.076, -0.155, 0
427.149, -0.156, 0
430.244, -0.156, 0
433.362, -0.157, 0
436.502, -0.157, 0
439.665, -0.157, 0
442.851, -0.156, 0
446.060, -0.156, 0
449.293, -0.155, 0
452.548, -0.153, 0
455.828, -0.152, 0
459.131, -0.150, 0
462.458, -0.148, 0
465.809, -0.146, 0
469.184, -0.143, 0
472.584, -0.141, 0
476.009, -0.138, 0
479.458, -0.134, 0
482.933, -0.131, 0
486.432, -0.127, 0
489.957, -0.123, 0
493.507, -0.119, 0
497.084, -0.115, 0
500.686, -0.110, 0
504.314, -0.105, 0
507.968, -0.100, 0
511.649, -0.095, 0
515.357, -0.090, 0
519.091, -0.084, 0
522.853, -0.078, 0
526.642, -0.072, 0
530.458, -0.066, 0
534.302, -0.059, 0
538.174, -0.053, 0
542.074, -0.046, 0
546.002, -0.039, 0
549.958, -0.031, 0
553.943, -0.024, 0
557.958, -0.016, 0
562.001, -0.008, 0
566.073, -0.000, 0
570.175, 0.008, 0
574.307, 0.017, 0
578.469, 0.025, 0
582.660, 0.034, 0
586.883, 0.043, 0
591.135, 0.053, 0
595.419, 0.062, 0
599.734, 0.072, 0
604.080, 0.081, 0
608.457, 0.091, 0
612.866, 0.101, 0
617.307, 0.112, 0
621.780, 0.122, 0
626.286, 0.133, 0
630.824, 0.144, 0
635.396, 0.155, 0
640.000, 0.166, 0
644.638, 0.177, 0
649.309, 0.189, 0
654.014, 0.201, 0
658.753, 0.212, 0
663.527, 0.224, 0
668.335, 0.237, 0
673.178, 0.249, 0
678.056, 0.262, 0
682.970, 0.274, 0
687.919, 0.288, 0
692.904, 0.302, 0
697.925, 0.315, 0
702.982, 0.329, 0
708.076, 0.343, 0
713.208, 0.357, 0
718.376, 0.371, 0
723.581, 0.385, 0
728.825, 0.399, 0
734.106, 0.414, 0
739.426, 0.428, 0
744.784, 0.443, 0
750.181, 0.457, 0
755.617, 0.472, 0
761.093, 0.487, 0
766.608, 0.502, 0
772.163, 0.517, 0
777.758, 0.532, 0
783.394, 0.547, 0
789.071, 0.563, 0
794.789, 0.581, 0
800.548, 0.597, 0
806.349, 0.612, 0
812.193, 0.628, 0
818.078, 0.643, 0
824.006, 0.659, 0
829.977, 0.676, 0
835.992, 0.694, 0
842.050, 0.710, 0
848.151, 0.726, 0
854.297, 0.743, 0
860.488, 0.762, 0
866.724, 0.781, 0
873.004, 0.798, 0
879.330, 0.815, 0
885.702, 0.834, 0
892.120, 0.851, 0
898.585, 0.869, 0
905.097, 0.888, 0
911.655, 0.907, 0
918.262, 0.928, 0
924.916, 0.950, 0
931.618, 0.969, 0
938.369, 0.988, 0
945.169, 1.008, 0
952.018, 1.027, 0
958.917, 1.046, 0
965.865, 1.069, 0
972.864, 1.089, 0
979.914, 1.109, 0
987.015, 1.132, 0
994.167, 1.152, 0
1001.371, 1.172, 0
1008.628, 1.195, 0
1015.937, 1.217, 0
1023.299, 1.240, 0
1030.714, 1.261, 0
1038.183, 1.281, 0
1045.706, 1.303, 0
1053.283, 1.325, 0
1060.916, 1.348, 0
1068.604, 1.374, 0
1076.347, 1.397, 0
1084.147, 1.420, 0
1092.003, 1.446, 0
1099.916, 1.472, 0
1107.887, 1.495, 0
1115.915, 1.519, 0
1124.001, 1.548, 0
1132.146, 1.574, 0
1140.350, 1.601, 0
1148.614, 1.630, 0
1156.937, 1.659, 0
1165.321, 1.686, 0
1173.765, 1.713, 0
1182.271, 1.743, 0
1190.838, 1.772, 0
1199.467, 1.803, 0
1208.159, 1.836, 0
1216.914, 1.865, 0
1225.732, 1.896, 0
1234.614, 1.926, 0
1243.561, 1.957, 0
1252.572, 1.991, 0
1261.649, 2.028, 0
1270.791, 2.065, 0
1280.000, 2.100, 0
1289.275, 2.139, 0
1298.618, 2.176, 0
1308.028, 2.213, 0
1317.507, 2.254, 0
1327.054, 2.292, 0
1336.670, 2.331, 0
1346.357, 2.374, 0
1356.113, 2.416, 0
1365.940, 2.459, 0
1375.838, 2.503, 0
1385.808, 2.548, 0
1395.850, 2.594, 0
1405.965, 2.640, 0
1416.153, 2.686, 0
1426.415, 2.731, 0
1436.751, 2.778, 0
1447.163, 2.828, 0
1457.649, 2.879, 0
1468.212, 2.926, 0
1478.851, 2.978, 0
1489.568, 3.030, 0
1500.362, 3.084, 0
1511.234, 3.142, 0
1522.185, 3.201, 0
1533.215, 3.260, 0
1544.326, 3.321, 0
1555.517, 3.383, 0
1566.789, 3.445, 0
1578.142, 3.508, 0
1589.578, 3.568, 0
1601.097, 3.634, 0
1612.699, 3.702, 0
1624.385, 3.772, 0
1636.156, 3.845, 0
1648.012, 3.917, 0
1659.955, 3.988, 0
1671.983, 4.059, 0
1684.099, 4.131, 0
1696.303, 4.205, 0
1708.595, 4.282, 0
1720.976, 4.362, 0
1733.447, 4.441, 0
1746.008, 4.519, 0
1758.661, 4.600, 0
1771.405, 4.682, 0
1784.241, 4.761, 0
1797.170, 4.841, 0
1810.193, 4.926, 0
1823.311, 5.009, 0
1836.523, 5.092, 0
1849.831, 5.178, 0
1863.236, 5.264, 0
1876.738, 5.349, 0
1890.338, 5.435, 0
1904.036, 5.521, 0
1917.833, 5.606, 0
1931.730, 5.693, 0
1945.729, 5.782, 0
1959.828, 5.868, 0
1974.030, 5.955, 0
1988.334, 6.044, 0
2002.743, 6.128, 0
2017.255, 6.210, 0
2031.873, 6.291, 0
2046.597, 6.372, 0
2061.428, 6.449, 0
2076.365, 6.529, 0
2091.412, 6.609, 0
2106.567, 6.690, 0
2121.832, 6.769, 0
2137.208, 6.849, 0
2152.695, 6.928, 0
2168.294, 7.007, 0
2184.007, 7.085, 0
2199.833, 7.164, 0
2215.774, 7.242, 0
2231.830, 7.319, 0
2248.003, 7.393, 0
2264.293, 7.468, 0
2280.701, 7.544, 0
2297.228, 7.616, 0
2313.874, 7.690, 0
2330.642, 7.766, 0
2347.530, 7.841, 0
2364.542, 7.909, 0
2381.676, 7.973, 0
2398.935, 8.036, 0
2416.318, 8.101, 0
2433.828, 8.164, 0
2451.464, 8.224, 0
2469.229, 8.285, 0
2487.122, 8.349, 0
2505.145, 8.407, 0
2523.298, 8.460, 0
2541.583, 8.511, 0
2560.000, 8.564, 0
2578.551, 8.617, 0
2597.236, 8.670, 0
2616.057, 8.722, 0
2635.014, 8.771, 0
2654.108, 8.816, 0
2673.341, 8.858, 0
2692.713, 8.900, 0
2712.226, 8.941, 0
2731.879, 8.981, 0
2751.676, 9.021, 0
2771.615, 9.060, 0
2791.700, 9.096, 0
2811.930, 9.129, 0
2832.306, 9.155, 0
2852.830, 9.179, 0
2873.503, 9.205, 0
2894.325, 9.232, 0
2915.299, 9.255, 0
2936.424, 9.276, 0
2957.703, 9.297, 0
2979.136, 9.318, 0
3000.724, 9.337, 0
3022.468, 9.355, 0
3044.370, 9.369, 0
3066.431, 9.382, 0
3088.652, 9.398, 0
3111.033, 9.412, 0
3133.577, 9.424, 0
3156.284, 9.431, 0
3179.156, 9.435, 0
3202.193, 9.437, 0
3225.398, 9.438, 0
3248.771, 9.436, 0
3272.312, 9.433, 0
3296.025, 9.433, 0
3319.909, 9.432, 0
3343.967, 9.427, 0
3368.198, 9.420, 0
3392.606, 9.413, 0
3417.190, 9.403, 0
3441.952, 9.390, 0
3466.894, 9.379, 0
3492.017, 9.370, 0
3517.321, 9.358, 0
3542.809, 9.342, 0
3568.482, 9.324, 0
3594.341, 9.306, 0
3620.387, 9.287, 0
3646.622, 9.267, 0
3673.046, 9.244, 0
3699.663, 9.223, 0
3726.472, 9.203, 0
3753.476, 9.182, 0
3780.675, 9.157, 0
3808.071, 9.135, 0
3835.666, 9.113, 0
3863.461, 9.087, 0
3891.457, 9.062, 0
3919.656, 9.035, 0
3948.060, 9.010, 0
3976.669, 8.988, 0
4005.486, 8.963, 0
4034.511, 8.934, 0
4063.747, 8.904, 0
4093.194, 8.873, 0
4122.855, 8.845, 0
4152.731, 8.818, 0
4182.824, 8.787, 0
4213.134, 8.760, 0
4243.664, 8.732, 0
4274.416, 8.701, 0
4305.390, 8.670, 0
4336.588, 8.639, 0
4368.013, 8.609, 0
4399.666, 8.579, 0
4431.547, 8.548, 0
4463.660, 8.518, 0
4496.005, 8.487, 0
4528.585, 8.453, 0
4561.401, 8.423, 0
4594.455, 8.391, 0
4627.749, 8.358, 0
4661.283, 8.329, 0
4695.061, 8.296, 0
4729.083, 8.263, 0
4763.352, 8.230, 0
4797.869, 8.201, 0
4832.637, 8.170, 0
4867.656, 8.138, 0
4902.929, 8.105, 0
4938.458, 8.073, 0
4974.244, 8.040, 0
5010.289, 8.010, 0
5046.596, 7.985, 0
5083.166, 7.958, 0
5120.000, 7.929, 0
5157.102, 7.901, 0
5194.472, 7.872, 0
5232.113, 7.844, 0
5270.027, 7.816, 0
5308.216, 7.788, 0
5346.682, 7.757, 0
5385.426, 7.725, 0
5424.451, 7.694, 0
5463.759, 7.665, 0
5503.352, 7.634, 0
5543.231, 7.603, 0
5583.399, 7.575, 0
5623.859, 7.542, 0
5664.612, 7.514, 0
5705.660, 7.487, 0
5747.006, 7.456, 0
5788.651, 7.426, 0
5830.598, 7.395, 0
5872.849, 7.364, 0
5915.406, 7.332, 0
5958.271, 7.300, 0
6001.447, 7.265, 0
6044.937, 7.225, 0
6088.740, 7.178, 0
6132.862, 7.131, 0
6177.303, 7.087, 0
6222.066, 7.040, 0
6267.154, 6.993, 0
6312.568, 6.946, 0
6358.312, 6.897, 0
6404.387, 6.847, 0
6450.796, 6.794, 0
6497.541, 6.739, 0
6544.625, 6.686, 0
6592.050, 6.632, 0
6639.818, 6.577, 0
6687.934, 6.520, 0
6736.397, 6.455, 0
6785.211, 6.387, 0
6834.380, 6.317, 0
6883.905, 6.246, 0
6933.789, 6.177, 0
6984.034, 6.104, 0
7034.643, 6.028, 0
7085.619, 5.952, 0
7136.964, 5.869, 0
7188.681, 5.781, 0
7240.773, 5.691, 0
7293.243, 5.599, 0
7346.093, 5.507, 0
7399.326, 5.413, 0
7452.944, 5.317, 0
7506.951, 5.221, 0
7561.350, 5.123, 0
7616.143, 5.025, 0
7671.332, 4.928, 0
7726.922, 4.827, 0
7782.915, 4.724, 0
7839.312, 4.621, 0
7896.120, 4.520, 0
7953.338, 4.416, 0
8010.971, 4.307, 0
8069.022, 4.193, 0
8127.493, 4.075, 0
8186.389, 3.959, 0
8245.711, 3.842, 0
8305.462, 3.723, 0
8365.647, 3.602, 0
8426.268, 3.483, 0
8487.328, 3.363, 0
8548.831, 3.235, 0
8610.779, 3.108, 0
8673.177, 2.981, 0
8736.026, 2.851, 0
8799.331, 2.721, 0
8863.095, 2.591, 0
8927.320, 2.460, 0
8992.011, 2.329, 0
9057.171, 2.195, 0
9122.803, 2.059, 0
9188.910, 1.921, 0
9255.497, 1.784, 0
9322.566, 1.645, 0
9390.121, 1.507, 0
9458.166, 1.369, 0
9526.704, 1.231, 0
9595.738, 1.089, 0
9665.273, 0.946, 0
9735.312, 0.804, 0
9805.857, 0.663, 0
9876.915, 0.522, 0
9948.487, 0.381, 0
10020.578, 0.240, 0
10093.191, 0.102, 0
10166.331, -0.033, 0
10240.000, -0.168, 0
10314.203, -0.303, 0
10388.944, -0.439, 0
10464.227, -0.574, 0
10540.055, -0.709, 0
10616.433, -0.844, 0
10693.363, -0.980, 0
10770.853, -1.118, 0
10848.902, -1.256, 0
10927.518, -1.393, 0
11006.703, -1.531, 0
11086.462, -1.668, 0
11166.799, -1.806, 0
11247.719, -1.945, 0
11329.224, -2.085, 0
11411.320, -2.225, 0
11494.012, -2.365, 0
11577.302, -2.506, 0
11661.195, -2.646, 0
11745.697, -2.786, 0
11830.812, -2.922, 0
11916.543, -3.054, 0
12002.895, -3.189, 0
12089.873, -3.322, 0
12177.480, -3.455, 0
12265.724, -3.588, 0
12354.606, -3.720, 0
12444.133, -3.854, 0
12534.309, -3.988, 0
12625.137, -4.124, 0
12716.624, -4.258, 0
12808.773, -4.394, 0
12901.592, -4.530, 0
12995.082, -4.665, 0
13089.250, -4.802, 0
13184.100, -4.939, 0
13279.637, -5.075, 0
13375.867, -5.208, 0
13472.794, -5.342, 0
13570.423, -5.477, 0
13668.760, -5.615, 0
13767.810, -5.750, 0
13867.577, -5.886, 0
13968.067, -6.023, 0
14069.285, -6.160, 0
14171.237, -6.296, 0
14273.928, -6.431, 0
14377.362, -6.568, 0
14481.547, -6.705, 0
14586.486, -6.842, 0
14692.186, -6.981, 0
14798.651, -7.120, 0
14905.889, -7.260, 0
15013.902, -7.407, 0
15122.700, -7.561, 0
15232.285, -7.717, 0
15342.664, -7.877, 0
15453.844, -8.037, 0
15565.829, -8.197, 0
15678.625, -8.361, 0
15792.239, -8.524, 0
15906.676, -8.688, 0
16021.942, -8.859, 0
16138.044, -9.049, 0
16254.986, -9.244, 0
16372.777, -9.436, 0
16491.422, -9.631, 0
16610.924, -9.830, 0
16731.295, -10.029, 0
16852.535, -10.230, 0
16974.656, -10.435, 0
17097.662, -10.659, 0
17221.559, -10.895, 0
17346.354, -11.133, 0
17472.053, -11.374, 0
17598.662, -11.615, 0
17726.189, -11.858, 0
17854.641, -12.105, 0
17984.021, -12.361, 0
18114.342, -12.631, 0
18245.605, -12.913, 0
18377.820, -13.200, 0
18510.994, -13.488, 0
18645.133, -13.780, 0
18780.242, -14.078, 0
18916.332, -14.378, 0
19053.408, -14.693, 0
19191.477, -15.023, 0
19330.547, -15.360, 0
19470.623, -15.703, 0
19611.715, -16.054, 0
19753.830, -16.411, 0
19896.975, -16.780, 0
