EarFun UA100 - Cheap DAC worth it?
Barry_Sound
Will this little DAC improve audio output of a generic PC? As far as I understand it´s a passive (USB powered) Hi Res Sabre chip with two output jacks.
antcollinet
UK/Cheshire
But even then - you are not going to improve the sound if there is nothing wrong with your PC analogue output.
Many, or most, PC's - even generic ones - have perfectly adequate built in DACs which for most people will be audibly transparent.
B
Barry_Sound
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Thanks I find it hard to navigate the review index. Is there a thumb drive DAC you would recommend?
I picked up a Tanchjim Space a little while ago, and also have a Qudelix. I'd recommend either, but there are quite a few that will do very well.
Dunring
Florida
The Tanchjim Space is $54 in shopping cart with coupons at AliExpress for the Cyber Monday sale. Absolutely can't go wrong with it.
