EarMen Donald DAC Review
This is a review and detailed measurements of the EarMen Donald MQA DAC USB stereo DAC. Yes, that is its real name with a play on Donald Duck. :) It was sent to me by the company and costs US $99 from the company direct. Unlike most DACs out there, the Donald DAC uses Crystal Semiconductor/Cirrus Logic CS43198 DAC chip.
The enclosure is quite a departure form typical DAC box:
The little stand can be slid forward or back and provides a few degrees of tilt. You can set it up to point the DAC up or down.
The back panel is minimalistic which is fine by me:
Earmen Donald USB DAC MQA Decoder Back Panel Inputs and Outputs USB-C Audio Review.jpg
Two USB-C connectors are provided. If you use the bottom one, it both powers the unit and provides data. However, you have the option of providing just power using the upper USB-C connector in which case the front LED nicely changes from blue to red color. I tested it both ways as you see below.
USB DAC Audio Measurements
When I first started testing the DAC, I did not think the external power supply would make a difference so I ran without it and got this:
This is very nice performance and ranks the Donald DAC quite high in our SINAD rankings (measure of noise and distortion):
After I was finished, I tested the unit with feeding it from a Samsung USB phone charger and to my surprise, it improved performance in a number of areas including the dashboard:
This may actually push the DAC in the blue bucket above! Notice how the spectrum above our 1 kHz tone is quieted down with just a few harmonic spikes remaining.
Dynamic range is very good:
I was impressed by IMD+noise vs level test performance:
Above is without external power. I retested it with external power supply but made no difference so I am not showing it.
External power made a big difference in jitter test:
Although audibly there is no difference.
32-tone test follows the same level of distortion we measured in the dashboard:
Linearity was solidly nailed:
There is just a tiny offset from -30 dB and lower which would have been good to not be there.
Filter performance is very good:
Given the above, I expected good THD+N relative to frequency but did not get it:
So I ran a spectrum analysis of a sample tone with the same wide bandwidth of 90 kHz:
The rise in noise floor is called "noise shaping." It is a technique used in DACs to reduce the noise in audible band into ultrasonic region. This is a good practice but does mess up measurements here as the bandwidth includes that accumulated noise.
Conclusion
It is nice to see some variety in DAC implementations once in a while. And deal with a company with a sense of humor! I went into this review thinking the device would not perform but it sure did. MQA decoding capability does not exist in desktop DACs in this price range so for people interested in that, the Donald DAC provides a unique offering.
Overall, I am going to put the EarMen Donald DAC on my recommended list.
The pink panthers just realized everything I am planting in the garden are for vegetarian animals. They are raising a stink and demanding that I plant some steak trees so they can get some meat! I searched on the Internet and there are some steak plants being sold from Nigeria for free! I just have to come up with $1000 shipping and customs fees. So would please donate a few dollars so I can make the panthers happy using : https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Matias
São Paulo, Brazil
Nice!
@amirm When you powered it without the Samsung charger, was it connected and powered directly from your PC or from an USB hub or what? Since this also happened with the Topping E30 DAC, maybe you should consider always using an external charger. I think it is what most users would do anyway.
Veri
The ultrasonics is the exact same issue as on the Meizu. Maybe it is inherent to the CS43198 (mobile) DAC chip.
Overall very good, but I guess not up to desktop DAC level.
Matias
São Paulo, Brazil
Yes, but it is all ultrasonic, because <20 kHz they are mostly below -110dB as the multitone shows.
3125b
Germany
Wow, that a very good implementation of a Cirrus Logic chip, off the top of my head I only know the lackluster ones from FiiO.
Though, owing an E30 myself, I really dig the remote and wouldn´t wanna miss it.
Koeitje
Why doesn't the dashboard THD+N match the THD+N vs Frequency graph?
Koeitje
Different bandwidth settings on the measuring device. The latter includes supersonic distortion that cannot be heard by humans.
Ah, those frequencies create ultra-sonic noise?
Illtrick
Seattle
Was really curious about this little fella. Thanks for adding it to the repo.
Xulonn
Boquete, Chiriqui, Panama
Accessories?
Umlautica
Of the distortion components. the relatively benign second order dominates. Really impressive measurements for a $99 DAC.
This comes in cheaper than the Khandas Tone board, after adding an enclosure. No cost wasted on controls or display might make this a good option for a PC based active crossover.
I use the USB hub on my monitor. It is cleaner than the USB port direct on my newer workstation.
The bandwidth is very different. Dashboard uses 22.4 kHz, the THD+N vs Frequency uses 90 kHz. The latter includes noise shaping and other noise sources so always degrades measured value.
maverickronin
Midwest, USA
Bachemar
The Sparrow has a normal name, but the product page compensates for that with an out of focus nude woman playing a cello.
Hmm.. And what’s wrong with that?
I actually find many of their other Product images with out of focus elements to be far more distracting from a composition perspective. They seem to overdo that style, and it actually detracts from the product. I find the image below particularly distracting - with my eye constantly being drawn to the background rather than the product itself.
The image Sparrow image with the nude cellist, is actually not terribly composed, and one of the better ones on that site.
