edd9000's System
edd9000
Frank told me I would like this forum so here I am. My system is currently a high sensitivity 3 way active system. The crossovers and room correction are DSP and software based.
Pc source running Logitech media server.
AES 16 sound card and Rosetta DAC
Various amplifiers, mostly diy Nelson Pass class A stuff.
Thomas savage
The Watchman
uk, taunton
A warm welcome to you and thanks for taking the time to share your system details , nice setup:)
Great to have a commodore lover in the house too..
edd9000
edd9000
Welcome to the forum indeed. Is your alias a play on HAL 9000?
And what is that little box way on top? Signal generator or distortion analyzer?
Yes a play on HAL9000, but obviously my nickname is Edd. Its been my screen name for a long time.
Its a distortion analyser, mostly an ornament but it does work.
RayDunzl
Central Scrutinizer
Riverview FL
Where are the measurements?
Oh, found one over here...
I had a C64... Wrote a little machine code for it and was amazed how fast it seemed at the time.
And made good use of the sound chip's capabilities.
FOR ... TO ... Calculate... PEEK... POKE... NEXT...
edd9000
edd9000
I still have a C64 and Amiga, they get plugged in now and then. I have plenty of measurements, are there any in particular you want to see, its quite tricky doing it all in room with such large speakers.
edd9000
edd9000
Hi Frank. Thanks for pointing me toward this forum, and good to see you at the weekend.
iridium
Your system would probably SHAME many multi-hundred thousand dollar systems.
Welcome & try-out our Fight Club when you feel rowdy.
iridium.
Sal1950
The Chicago Crusher
Central Fl
VERY nice DIY rig. I admire you guys with the "where with all" to build you own gear! I haven't been able to do that since I was building kits back in the 60s.
Thanks also for contributing to our members gear header. It's really nice to be able to put together a person with his gear
Ah, when you said "Frank" I thought you meant our australian member! Good to have the clarification. :) Thank you Frank Dernie for pointing him our way.
Phew, had me worried there for a minute too. LOL
RayDunzl
Central Scrutinizer
Riverview FL
Nothing in particular. Whatever you're proud of or concerned about.
FR, phase, impulse, step -- that's most of what I end up looking at here.
I'm anti-distortion, so I look at that sometimes.
The waterfall has made me think my dipoles have a 10dB advantage over my coned speakers when looking at direct sound vs room reflections, but without everyone on the same page for settings it's not very useful between systems. Spectrogram, rarely, just played with it.
I do measures for left/right/both speakers... I discovered I have a room anomaly where the left/right go 180 degrees out of phase with each other around 48Hz - the l/r response is good, combined they dig a hole. It doesn't seem to be audible with music, I wouldn't have guessed it was there before measuring.
As for being tricky to measure in-room, well, does that also make them tricky to listen to? I do my measures from the listening position unless there's some special case, because, I figure that's where it counts.
edd9000
edd9000
The main concern was power compression and headroom. I wanted to play wide dynamic range recordings with no compression and preferably with little distortion at high spl. This meant high sensitivity drivers with high power handling.
Step response:
Waterfall
Uncorrected response measured at many places around the room to confirm good off axis behaviour
A little ragged in the FR but it at least shows the system is linear phase:
Distortion, not great as it was in a giant room but its the only one I have on this pc, I will look for one done in my room.
edd9000
edd9000
Indeed, I really use measurements for my self to compare, but they have to be taken with a pinch of salt and may not be comparable to other methods etc, not everyone realises this.
edd9000
edd9000
Distortion, listening position, no room correction. above 300hz it peaks at about 0.5% below around 1%.
Of course this is the whole system including the mic, and room effects, but I cant seem to find a 1m measurement saved, ill have a play next time I recalibrate.
sergeauckland
Suffolk UK
Hi Edd, nice to see you here. I would hope the distortion analyser still works! I still use my Ferrograph RTS2 pretty much daily, but mostly as a signal generator and level meter. I use a PC for distortion measurements, mostly, as pretty much all items now have less distortion than the analogue meter can measure.
S
