Edifier MR4 measurements (It's probably been upgraded.)
Nuyes
Reviewer
South Korea
Hi Guys!
I actually measured Edifier's MR4 in its early days, too.
This is what I had measured before using Klippel's equipment and software, and the FR(on-axis) of the speaker tended to be similar to what @amirm had measured.
Anyway. In the Korean audio community where I'm active, the MR4's popularity hasn't waned since then.
However, many people lamented the lack of Multitone test (by Klippel) data for this speaker,
I was able to get a relatively recent one from a member.
So let's get started!
Frequency Response
I panicked as I organized this data.
What the heck was going on...
The speaker changed.
It's incredibly flat compared to before.
I believe the product has been upgraded.
Directivity
The horizontal directivity is very smooth.
Beamwidth
Polar plot
The directivity(back and sides) isn't the smoothest, but for the price, it's forgivable.
(You can currently find them in the $50 to $60 range in South Korea).
THD
(Given the size of these speakers, I measured them at 90dB SPL instead of 95dB SPL.)
I use CHD to represent the THD% plot.
This calculates the percentage of each overtone component based on the average sound pressure from 200 Hz to 10 kHz, which I prefer for relative plots.
Compare to the passive model.
Multitone test
I wouldn't call it super clean, but it's pretty good for the price point.
(I keep emphasizing price, and since I live in South Korea, I can't help but think in terms of prices here.
Please forgive me.)
Original vs 80Hz~
Mode comparison
Multitone distortion each SPL
Compression test
Probably the limiter on the built-in amplifier was triggered.
Deviation between Active and Passive model.
Impact of Music mode.
Crosstalk test (L to R)
Finally.
THD and MD measurement data can tell you a lot about a loudspeaker.
And when we look at this speaker based on that, it's a pretty compliant speaker.
However, I did hear some pretty annoying noise from the active model when measuring this speaker.
(If you listen to music with a lot of bass, you can probably relate.)
And when I looked at the data later, it was already measured.
This is the Port nearfiled measurement data for this speaker.
As it turned out, the noise was stronger on the rear amplifier plate than on the port, but it was also measurable on the port.
And this was confirmed by the ID (Impulsive Distortion) and HOHD (High Order Harmonic Distortion) data.
These are things that may or may not be slightly detectable in THD or MD measurements, but are actually much more audible to the human ear.
Low-order harmonic distortion can be treated as timbre, but in this case it is not, so it is clearly heard as noise.
Thanks for reading this review. :)
Huang Jerry
Sing-a-Pore; Hangzhou.
Excellent review! Funny story, I did some impromptu measurements using the umik-1 (just for fun) on the older version before I returned it as the passive speaker is not working.
I received the possibly new version as a replacement and the FR is indeed different, no consensus on the actual improvement in FR though as there are too many variables in the testing environment.
Nuyes
Nuyes
Reviewer
South Korea
I am sure that what you have experienced is probably the truth.
I once collected four passive models of the MR4 and measured the deviation between each unit.
As a low-end product, there was some variation, but I never saw anything in the measurement data that would make it look like a completely different product.
wwenze
Ooo, flat. That can make many high scoring speakers here worried especially coming from an affordable speaker.
This presents a philosophical problem - How long can reviews be before they become inaccurate?
thewas
Thank you for sharing, am positively surprised by their performance considering you can get them also in Europe for 100€ pair price, might get them for my work in the future.
@amirm, maybe you could pin the review at the top as its a decent low budget choice for beginners?
JktHifi
Is there any difference between TRS and RCA input? TRS better or almost the same?
MaxwellsEq
I think it really depends. For relatively cheap speakers, probably no more than a year. Professional monitors (designed for studios) should really be consistent for a number of years (to avoid the need to change everything if one of the monitors fails in year 3). The extreme case in the BBC LS3/5a which has had to be consistent over decades!
sejarzo
Probably a great choice for anyone who needs computer speakers in that price range for general use at low to moderate volumes.
henologist
Austin, TX
Thanks for the measurements! There's a lot of solid competition in that price bracket right now, and this seems like one of the strongest contenders. I might grab a pair for the office.
Bleib
Sweden
Uh. How would one now if one would receive a new version?
sejarzo
We should dig deeper. On amazon they talk 2.0 but what that means? Who knows? ;)
I saw that BestBuy advertises them as "Edifier MR4 2.0" but I believe that is done simply to be clear that these are a 2.0 system rather than 2.1.
Bleib
Sweden
Companies are poor with these things. A simply V2 would work..
