Edifier MR4 + Presonus Sub 8BT vs. bigger speakers
Hardtogain
Hello, I want to invest in a PC desktop setup and after some reading and information gathered (good and bad) I came to these options:
1. Edifier MR4 + Presonus Sub 8BT + Focusrite scarlett solo 3rd = 400 euros
2. Mackie MR524 or JBL 305p MK II + Focusrite scarlett solo 3rd = 350 euros
Room size is 4m x 6m
I'm more incline at the Edifier option being that is a smaller speaker = more desk room and by ading the sub would get me more or less the same sound quality as the second option (atleast this is my thought process regarding this subject)
So feel free to jump in with other options\thoughts.
Thank you.
another option for you: kali lp-unf
designed to be used on a desk, front firing ports for more placement freedom, built in DAC and usb input so if you don't want to record you can skip the interface
komhst
The 1st option is more practical, more "flexible" and giving a superior sound.
H
Hardtogain
You are right regarding the audio interface, I don't need such an expensive one being that I don't record.
I just need one for the speakers and my AKG K371 headphones so I will look for something cheaper.
As for kali lp-unf being so new can't find too much information/reviews about them but so far I see them as a niche product but time will tell.
That was also my presumption, thanks.
