ozzy9832001
- Joined
- Feb 19, 2023
- Messages
- 408
- Likes
- 258
Hey guys,
I recently picked up these speakers off e-bay to replace my Kanto YU6 speakers. I was always a bit disappointed with them even though they seemed to get decent reviews.
The 2850DB seem to lack a lot of information and the only reviews I could find about them were just videos on you tube. They were released in the US in 2021.
These speakers are on the larger size for "book shelf" speakers and really seem to push the boundaries of what a bookshelf can be. They measure at 18"Hx10"Wx12D. Each speaker weighs approx. 23.5lbs.
an active design and come with a wide array of inputs for all your needs. 2xRCA, 1xOptical (Toslink), Coax and Bluetooth 5) and 1xSubwoofer OUT. The speaker cable bridging the active right unit to left is attached on the right speaker and an XLR connection on the left. The cable length is approx. 8ft long. Unit comes with a remote control with very basic functionality (Power, mute, volume, track advance/back/play, input select, mute and bluetooth toggle). Unit has a SUB OUT for further bass extension. The speakers come with all cables to hook up your devices except for COAX. The RCA Cable is both RCA to RCA and RCA to 3.5mm (nice touch). The remote is powered by one CR2032 battery (included).
As for the speakers themselves they are made of some form of MDF, though they certainly do not feel cheap.
Side of the speaker:
Speaker has volume control and DRC - +/-6dB Bass/Treble. ON/OFF switch on back of unit.
As for the front:
Speaker is a ported design with an 8" woofer, 4" mid range and 3/4 tweeter. The unit comes with removable grills to give them a sleek and classic look.
As far as tonality is concerned the speakers are flat. Really flat. A slight brightness to the upper mid range, but it's not harsh or shrill. The bass is extremely well balanced and warm. It's tight. Not boomy or boxy and can stand out without being overpowering. Listening to some crazy metal bass songs was highly enjoyable and offered a great experience that you typically don't see in a speaker in this price range.
The speakers frequency response is: 42hz - 20khz
It is important even with the 8" woofer that Edifier included a subwoofer out. The connection is 3.5mm. The speakers come with a 3.5mm to RCA cable. It is short. Real short. About 4' if that. You'll probably need a longer one.
The subwoofer port is hard set to a cross over of 100hz at a slope of 24dB/OCT. To me, I like the slightly higher than THX crossover. I also like how it slopes off and allows the sub to really handle the low end. Blending is natural and effortless.
Overall, these speakers are tight. They are a great addition to an office workspace or someone looking for a bigger speaker but not willing to pay the really high cost. Bass is warm, detailed but not overpowered. Mids and treble are bright but not shrill and fatiguing. Out of the box they sounded great and that is a good sign for when my ears burn in to the speakers.
I cannot for the life of me understand why these speakers aren't talked about more or why reviews are so scarce.
Retail cost is: $449 on Amazon. I sold my Kanto YU6 + SUB 6 to recoup some of the price. Well worth it.
As for the front:
