Effect of Speaker Cable Length Mismatch
radix
Wouldn't doing room correction (dirac, audyssey, etc.) make any differences in speaker cable length irrelevant? I'd also think that differences in room placement of each speaker would swamp the effects of small cable distance imbalance. Is that wrong?
restorer-john
I've tried with another set of speakers and cables and found out that the problem is on the amp, since the behavior is the same on both sets, which are very different. It requires the volume to reach some threshold to start working properly. Before this, I hear some noise and only one of the speakers work, randomly every time I switch on and off, without changing anything else. After this threshold has been reached, I can turn down the volume again and everything works perfectly at any level.
You have most likely, an oxidised/pitted set of speaker relay contacts. Very, common.
The 'burst' of volume is required to 'cut through' the oxide and then all is well until next time or a period down the track.
Prior to turning it up, one speaker is lower in level and/or distorted.
To confirm it is the relay, take the cover off the amp, turn it on and play at the level where the issue occurs. Tap the speaker relay firmly with a wooden chopstick (safety first) and see if it instantly solves the issue. All you need do is either replace (preferable) the relay or alternately, remove it, pop the cover and clean the contacts with some 2000+ grit wet and dry cut into a thin streamer-like strip, folded over and pulled through the NO contacts.
DonH56
DonH56
Monument, CO
Good catch, my amps have not had relays in years so I forgot about that. My solution for cleaning contacts "back then" was emery cloth. You can get it in sheets or spools.
Mnyb
Sweden, Västerås
Yes I would think the differences between L and R side of the room to dominate this ? And add the differences between L and R speaker.
But it’s good to know the magnitude off the problem and take action ( or not ) .
xaviescacs
La Garriga, Barcelona
Thanks a lot. :) I've started this thread to stop polluting this one.
MKreroo
this from Oratory might be a good addition to the thread
kongwee
Longer mean increase resistance and reactance. Harmonic are different along the audio frequency. Already in textbook.
fpitas
Northern Virginia, USA
fpitas
Yeah? That must be a very interesting textbook.
fpitas
Lol yeah. My bad
fpitas
i blame the delay in the unequal cables.
