Penelinfi
- Joined
- Apr 22, 2021
- Messages
- 456
- Likes
- 345
A king bed isn't as comfortable inside a wardrobe because a wardrobe is seldom big enough to fit one. I guess another analogy is, you wouldn't use 2x 23 inch monitors with 720p for your work...I did get some helpful pointers for which I'm grateful and some less helpful suggestion, for example buy a new flat, replace the amp that you just bought and is the best and biggest investment into decent setup so far.
King bed would be just as comfortable inside a walk in wardrobe as it is in on the floor and if you are looking for a comfortable bed try natural lateks.
Is one suppose to not have a mind of his own and just do whatever someone recommended in comments?
Concept of limited space shouldn't be to hard to grasp even if ones garage is as big as my flat and should I be sorry for trying to make the best of what I have?
Anyway for anyone following I'll buy a sub, set sub and speaker filters properly, EQ the frequencies around 125-130 hz and it should be fine, later I'll probably invest in Kef LS50.
Thanks again to everyone that helped even to those that weren't really helping.
If you are facing similar problems this video should help you pinpoint the problematic frequency range, 120 to 130 hz seems to be common range for the boominess I was describing.
I just see many requests for help, and then the person seems to come up with excuses why they "can't" do that, and then they go and do what they were going to do before, anyway.
For what it's worth, a speaker you can aim at your ears, + EQ (adjusting your own filters is key) is basically all you can do given your imposed constraints. Maybe add some absorber on the desk. But I guess that's going to "look ugly and take up what little desk space there is"
