Electro Voice Q series Amps
Suresh kumar
Hai,
Does any one knows about EV Q99 power Amplifier ,Cant find any Usefull
Reviews in Google,But this is the Current Running Amp From EV.,,It will be helpfull some one give me a review abt this....,am confused to buy crown or Ev ...
Specification -
  • Maximum midband output power: 1250W @ 2 ohms, 900W @ 4 ohms, 550W @ 8 ohms (THD = 1%, 1 kHz, Dual-channel)
  • Rated output power: 800W @ 4 ohms, 400W @ 8 ohms (THD < 0.1%, 20Hz“20kHz)
    Maximum single-channel output power (Dynamic-headroom IHF-A): 2450W @ 2 ohms, 1400W @ 4 ohms, 700W @ 8 ohms
  • Maximum single-channel output power (
  • Continuous, 1 kHz): 1700W @ 2 ohms, 1100W @ 4 ohms, 630W @ 8 ohms
  • Maximum bridged output power (THD=1%, 1kHz): 2800W @ 4 ohms, 1800W @ 8 ohms
  • Maximum RMS voltage swing: 78.8V
  • Power bandwidth (THD = 1%, ref. 1kHz, half power @ 4 ohms): < 10Hz“30kHz
    Voltage gain (ref. 1kHz): 32dB
  • Input sensitivity: +5.1dBu
  • THD at rated output power (MBW = 80 kHz, 1 kHz): < 0.03%
    IMD-SMPTE (60 Hz, 7 kHz): < 0.1%
    DIM30 (3.15 kHz, 15 kHz): < 0.05%
    Maximum Input Level: +21 dBu (8.69 Vrms)
  • Crosstalk (ref. 1 kHz, at rated output power) < -80 dB
    Frequency Response (ref. 1 kHz 10Hz“40 Hz (±1 dB)
  • Input Impedance (active balanced): 20 kOhm
  • Damping Factor: 1 kHz > 300
  • Slew rate: 27 V/ Μs
  • Signal-to-noise-ratio amplifier (A-weighted): >109 dB
  • Output noise (A-weighted): < -71dBu
    Output stage topology: Class H
  • Power consumption (1/8 maximum power @ 4 ohms): 700W
  • Protection: Audio limiters, high temperature, DC, HF, Back-EMF, peak current limiters, inrush current limiters, turn-on delay
  • Cooling: Front-to-rear, 3-stage fans
  • Ambient temperature limits: 40”105“F
  • Safety Class: I
  • Dimensions: 483mm W x 88.1mm H x 421.5mm D
  • Weight: 35 lb.
  • Signal processing: LPN, switchable
tomtoo
Germany
Interesting, designd and engineered in germany, assembled in china for a us company. Thats globalisation.
Edit: But hey they should realy design in italy. ; )
