EQ in ROON guidance
Womaz
Newcastle - England
Ok so as you can see I am a total novice with this . This is my very basic attempt to have a short term fix to my current room issues
in time I will look to do something on a more permanent basis.
I am trying to fix a bit of brightness and a boomy bass . Can I improve things further ?
Joachim Herbert
Munich, Germany
What is this based on?
Purité Audio
Industry Insider
Barrowmaster
London
Yes you need to acoustically measure first, REW and a microphone.
Womaz
Womaz
Newcastle - England
Hmm not a lot really.
I read a little on EQ on the Roon forum from what I remember. I vaguely recall seeeing a chart about the impact of changing some EQ settings
I know its a crude attempt but it has improved things. Its definitely not as bright but I have definitely lost some of the bass impact.
GDK
Toronto
This is a good guide, but you need some form of calibrated measurement mic, like a UMIK-1.
Womaz
Womaz
Newcastle - England
In the longer term I will adress the issues in a more permanent way, this is just a short term fix until I know how my Room will be decortated and furnished etc.
Womaz
Womaz
Newcastle - England
Thanks for the post.
Yes that is a good guide but I am a total novice and just dont have the time at this stage to investiagte this further. I will revist this page though.
Like I say at this stage I am sort of looking for a quick temporary fix
GDK
Toronto
Then I would say play around until you find some settings that you like. It seems like you are on the right track.
Unfortunately, every room and speaker is different and therefore the community is likely to be of limited assistance without seeing some proper measurements, which would allow us to identify the issues you are having. We would simply be stabbing in the dark otherwise.
Womaz
Womaz
Newcastle - England
Yeah I understand and you are probably right
it was playing around a little that got me to the above and like I say it definitely has helped, especially with the brightness
i moved house and my new room is much smaller than my old room . I think maybe my speakers are too big for the new room , but for me they were a significant investment so they are staying . I will just have to work around them.
I will also read about using a mic etc .
SKBubba
Try changing the high frequncy eq from peak/dip to high shelf and adjust the frequecy till the "brightness" is gone, and make q something like .5 to make the slope smoother. On the bass, "boomy" is usually around 125hz as you have it set. Try increasing q to make the dip narrower.
Womaz
Womaz
Newcastle - England
Try changing the second one from peak/dip to high shelf and adjust the frequecy till the "brightness" is gone. On the bass, "boomy" is usually around 125hz as you have it set. Try increasing q to make the dip narrower.
Thank you.
I think I just about understand your post so yes I will try this and experiment a little
Purité Audio
Industry Insider
Barrowmaster
London
Without measurement you are working in the dark, it is the first step, you can ( in the meantime before you buy a microphone) enter your room’s dimensions into an online room mode calculator,
That will give you an idea but not as accurate as measurement .
Womaz
Womaz
Newcastle - England
See my edit about q setting for high shelf.
It’s really difficult this
I think I prefer the bass left alone so have removed the band 2 setting
Band 1 is as shown . It has definitely toned down the brightness , but seems to have lost some of the life.
Womaz
Womaz
Newcastle - England
So far I think I prefer this ……will keep experimenting
when I change it to high shelf it seems to lose a bit of life in the music
Womaz
Womaz
Newcastle - England
I will have a read up on the roon guide to using this as I am only really adjustjng one band and there are 5 available so I need to investigate
I guess there is no quick fix
SKBubba
Got it. The high shelf simulates a sort of rolloff, and it seems you have the issue in a particular band. You could still try adjusting the q to values less than one to smooth out the curve a little or increasing a little to zone in in a specific frequency.. But yes, doing it by ear is a lot of trial and error. Looks like you are getting it zoned in.
curiouspeter
San Francisco Bay Area
I used to do "room correction" using Roon PEQ. I used REW with a miniDSP microphone to determine the peaks. It definitely helped, as I had a nasty room mode.
I suspected that I could do better, so I got RoomPerfect. Now it is MUCH better.
Yes, the cut at 3000 Hz will fix brightness. I created an EQ curve in case I want some warmth in certain music. However, I mostly listen to classical and I usually just go flat.
euge_lee
My favorite feature in Roon is the ability to use convolution filters. Check out homeaudiofidelity.com and with a measurement microphone using their tool, you can measure your room and send Thierry@HAF the info and he'll send you back professionally made corrections for your room. You don't even need to learn how to use REW. Best bang for the buck that I've found.
curiouspeter
Using REW to produce convolution filters for Roon is very convoluted.
