concorde1
- Joined
- Mar 15, 2021
- Messages
- 366
- Likes
- 282
Klipsch HP-3
https://raw.githubusercontent.com/jaakkopasanen/AutoEq/master/results/crinacle/gras_43ag-7_harman_over-ear_2018/Klipsch Heritage HP-3/Klipsch Heritage HP-3.png
As you can see there is a 6kHz dip (about 3dBr) in EQ'd. So can I correct this by Peaking Filter at 6k with gain = 3dB and Q = 1.09?
There is a 9kHz dip (about 8dBr). Similar correction.
Audeze LCD-2F
https://www.dropbox.com/s/bqkdze8w82zguyj/Audeze LCD-2 Fazor.pdf?dl=0
There is a dip in EQ'd at 4.5kHz (about 5dBr). Can I correct this similarly with gain = 5dB and Q = 1.15?
Philips Fidelio X2HR
https://www.dropbox.com/s/b09edinwg6tw5vi/Philips Fidelio X2HR.pdf?dl=0
Dip at 8.5kHz (about 5dBr). Similar correction.
But I believe it is more complicated than that. I'm trying to relate Sound Pressure Level dBr on the graphs, with dB in EQ software.
I expect to scale from "dB" to "dBr" you need to know the sensitivity of the headphone and other parameters, then use an equation to calculate dBr?
Audeze LCD-2F
