Ethan Winer Builds a Wire Null Tester
Ethan has built a null tester for testing audio interconnects to reveal differences between them. He has a new video on it which is kind of long on intro but then gets to the meat of the argument toward the last third:
BTW, I am offering some of my high-end cables (Transparent Audio) to Ethan for testing. Alas, they are old (bought them 15+ years ago). If anyone has newer ones and willing to loan them to Ethan, that would be great.
solderdude
The Neitherlands
I built one as well about 25 years ago and brought me very valuable insight...
It is rather basic but does the same as Ethan's version.
As a meter I used my Nakamichi. Also used that to record nulls when nulling amps and speaker wires under real loads.
The music was playing so loud you can't hear the nulls.
My gain only went to 40dB so I could see around -60dB on the meter but of course could record much deeper than that.
The nulling pot was a multiturn pot. Just without the fancy dial.
I agree totally with Ethan by the way.
Cosmik
Just watched the last third...
It would be interesting to call the bluff of the 'micro diode' proponents and actually try to create some deliberately using grossly oxidized junctions and so on.
Blumlein 88
I've done a variety of wire null tests. People just don't want to know the truth for the most part. I've used wires in DAC/ADC loopbacks. Record the various wires and then null the file. You usually get the same result of a wire vs itself 5 minutes later as you do between two different wires of the same length. You can see a difference in nulls due to timing between say 1 meter and 3 meter wires due to the several nanosecond delay. That is how sensitive such tests are. I've tried directional wires where it is the wire vs itself reversed. Nothing there.
It is nice that people do such things every so often. It is a bit disheartening that you can't show this a time or two and kill the stupid myth.
JJB70
Singapore
If people want to believe something enough then they will believe it regardless of rational evidence. The various myths around cables have been demonstrated as being just that, myths, countless times yet people still buy into it all.
solderdude
The Neitherlands
Speaker cables did not null 'perfectly' and had to be a few meters tops because of delay between input and output.
Nulls between speaker cables and a small resistor were similar so I think for speaker cables only resistive issues exist.
JJB70
Singapore
I like the bit at the end of the video which illustrates the standard audiophool response to rational thought - kick him out of the club and delete his posts. There was some classic stuff on Mark Waldrep's site a few months ago with the same reaction from audiophoolery.
Thomas savage
The Watchman
uk, taunton
Umm, when one clearly sets themselves apart as a antagonist you can expect a reaction. In this regard Winer often clips his own wings with a unnecessarily belligerent attitude at times which is a real shame as he’s done a great service to the hobby imo and continues to do so as well as being quite amusing at times.
DuxServit
I watched the whole thing— thanks @Amir for posting such a good piece. It’d be great if ASR could have a thread on Ethan’s tests using different cables.
Love to see how the $22K cable performs ;)
SIY
Alfred, NY
Reasoning will never make a Man correct an ill Opinion, which by Reasoning he never acquired - Jonathan Swift
solderdude
The Neitherlands
There will be nothing to see :D ... just the noise from the nulling device.
Still... the cable believers will keep 'believing' simply because the audible difference is like 'night & day' or at least 'quite obvious' or should I say 'evident' to them.
Stupid scientific minded idiots... that's what we are.
Nulling tests... they can't work because it uses stupid op-amps... everyone knows op-amps removes 'the analog' from sound.
Why didn't he use tubes ?
Urmm... the video is a hoax ... it's rigged.
but... but ... USB cables, ethernet cables, 'digital' cables and... and...
Thomas savage
The Watchman
uk, taunton
Having been doing this ASR thing for a few years it seems to me that if there’s a audible difference there should be a clear and detectable difference in the signal . In fact we can see many little differences that aren’t audible so I’m not sure there’s any mystery really and if there is it’s to do with psychological ‘priming ‘ within the listener.
JJB70
Singapore
Bah, he's a rank amateur, now Peter Aczel in his prime, there was a guy who really could antagonise when the mood took him!
Cosmik
Is there a way to say "You're all wrong, irrational, superstitious and gullible." non-belligerently? :)
I don't think Ethan's test will do much to change any of the die-hard believer's mind. The mechanism of the test is too complicated for them to grasp what it is demonstrating.
What it is good for is what Ethan says at the start: that is, we say cables make no difference but we don't have good data to point to. In that regard, it provides more evidence for us to be convinced of its truth.
tomelex
So called Midwest, USA
Nice Work Ethan!
I think Ethan did a good job with his preamble, he is a good teacher and is trying to teach the reasons why his null test is applicable and reasons whey it would not be (example if you don't account for phase etc).
I have learned from Ethan over the years and he is an asset to the audio community, and to this great site that Amir created. Thanks for posting Amir, great video for this site, recommend sticky status at some point. Also appreciate you sent him your high end cable for test.
tomelex
as you get older your tolerance for un truths get very low, so I understand him pretty well, its almost impossible to sway faith based folks ideas or beliefs, and as long as they have their counterparts there they feel secure, yet will never submit to a substantial monentary bet or proper blind test. The guy who impresses me the most is Amir, the stuff he has had thrown at him and stayed calm amazes me.
