adelaidestevens
- Joined
- Jun 24, 2022
- Messages
- 38
- Likes
- 11
do the double flange fit you? since it comes in 4 sizes. I find them to be a bit more comfortable than the triple flange, aside from isolation they sound pretty similar to the triple given the correct fit.Very much agree though after a few years of ownership I've settled on 1 EQ filter as I finally decided the mids are a touch too forward for me:
1700Hz -3dB Q=1.4
I'd go further and say I think they actually sound better than my HD6XX. I just can't wear the Etys all the time as I actually need to hear stuff sometimes
I just wish there was a triple flange size in between the small and large. I've resorted to buying the small frosted tips with long stem and cutting it down a little, but I can't find where to buy them anymore.
Also regarding the mids, they only sound shouty to me with vocal forwards recordings like Norah Jones for example, otherwise they're pretty bang on with 6XX/650. Then again I only listen at around 60 dB, so it might sound different to peeps who listens at 70 or 80 dB
