Looks like an HF-206 horn tweeter in there.
If you're referring to the Esquire (?) It's an EV T35BLooks like an HF-206 horn tweeter in there.
I got that tweeter's identity confused with a University model HF-206; they look similar.Looks like an HF-206 horn tweeter in there.
I believe there was a connection between University and EV at one point.I got that tweeter's identity confused with a University model HF-206; they look similar.
Later, yes. Not in the early days of the T35 family.I believe there was a connection between University and EV at one point.
Hypersonic, huh. Yeah it looks vaguely exponential. And not cheap, that would be about $350 now.Later, yes. Not in the early days of the T35 family.
The "Cobraflex" horn, e.g., started life as a University product, but ended up with EV branding.
Heck, I think they are still selling the Cobraflex!
The HF-206 was a University horn/driver. I drew a blank when @egellings invoked it, because I was thinking "EV".
Das Ding an sich Note the University Cobraflex, too.
source: https://www.alliedcatalogs.com/flipbook/1960_allied_radio_catalog.html
The EV T-35, T-35B, T-350, and TW-35 tweeters used a diffraction horn that EV was quite proud of back in the day.
Pretty sure the HF=206 had an exponential horn (EDIT: says "reciprocating flare" in the catalog scan I posted, doesn't it? ).
The horn itself may well be exponential, so, yeah, I was a bit sloppy in teasing that apart from the characteristics of the throat. Sorry.Hypersonic, huh. Yeah it looks vaguely exponential. And not cheap, that would be about $350 now.
I recall the tweeters on the Sentry III were vertical, too. I think.The horn itself may well be exponential, so, yeah, I was a bit sloppy in teasing that apart from the characteristics of the throat. Sorry.
That said, I am happy to spend some more forum bandwidth on these tweeters.
Col. Paul W. Klipsch was quite enamored of them for reasons known only to him. In Klipsch's (metaphorical) hands, the T35 (known in Klipsch parlance as the "K-77") made a nasty, harsh name for itself. EV's crossovers tended to get better out of the same drivers, but I don't know why (maybe higher XO frequency? I don't know).
The Col. also either didn't understand (not likely) or didn't care (much more likely -- he was nothing if not an iconoclast! ) that the T35 was meant to be oriented with the long axis of the horn vertical to provide the best horizontal dispersion. Some of his loudspeakers oriented the T35 correctly, but most of them... did not.
There were some "vertical horn" Cornwalls, e.g.
(random internet image of a pair of mirror-imaged 'vertical Cornwalls')
My (long gone) 1974 Cornies, and indeed most of them using the EV tweeter and horn, had the MR and tweeter horns horizontal.
Derp.
Pay no heed to the "damping" applied to the MR horn -- a vain attempt to calm that sucka down!
The only thing that really would improve the Cornwall involves an accelerant and a match.
