multisport4me
- Joined
- Jul 30, 2021
- Messages
- 314
- Likes
- 291
Okay, someone suggested adding a spectrum analyzer to the DMP-A6 ala the latest Topping D70 Pro. I did a quick search of the Google Store and I found this. @mirror88 can this be loaded up as an app on the DMP-A6? https://play.google.com/store/apps/details?id=com.bti.sAnalyzer&hl=en_US&gl=US
UPDATE: I was able to install it but it doesn't do anything. It occured to me after I deinstalled it that Eversolo bypasses the standard Android audio driver(s) so perhaps if I disable the EOS audio engine it will work. But obviously this means Eversolo would need to implement their own spectrum analyzer or get a company like this one to build support for EOS into their APK. Good enough as a proof of concept though if I can get it to work with the standard Android audio engine.
