EverSolo Z8 DAC & Amp Review
Rate this DAC & HP Amp
    Votes: 3 0.9%
    Votes: 3 0.9%
    Votes: 67 20.2%
    Votes: 259 78.0%
JSmith
Algol Perseus
Any other user reviews of this unit to share?
JSmith
multisport4me
I just picked one up. It came with the latest firmware (v.52) loaded up. The USB input works perfectly with my Roon ROCK. The Coax SPDIF does not work well with any source or format. I hear music for 2-3 seconds and it goes silent. I might back rev firmware to v.42 where it appears they first fixed the SPDIF issues...but then, v.52 was also supposed to fix the SPDIF issues. So my review so far - potentially very cool, but so far, very wonky DAC that might be going back to Amazon.
Hawkmoon
@multisport4me Sorry to hear about your SPDIF issues. I just got mine and have been testing it for a few days now. I have tried my Node 2i vs coaxial into the Z8 and it performs flawlessly - no drop outs. Same on USB connected to my Innuos Zen Mark 3 streamer. What are you connecting up to the Z8 via coaxial ? Mine is on the v52 fw which came installed. Tried different cable?
multisport4me
I was experimenting running coax SPDIF out of my PS Audio Nuwave as I don't like it as a DAC but as an A/D its a nice bit of kit. The cable works fine from the Nuwave into my Marantz AV10, which is likely where I'll end up keeping it. I just don't like the idea of buying something new like this and knowing an input is broken....whether I end up using it or not. I guess I can try a different cable - worth a shot.
multisport4me
Well it turns out it is in fact the Nuwave. I found that it is also now doing it with my AV10. Tried to flash firmware, reset, etc. to no avail. Crap. I really liked using it as an A2D and being able to use any cartridge I wanted and any DAC I wanted for the most part.
Any phone A2D type devices out there with selectable gains, loading options, MM/MC support? I'm guessing PS Audio will charge me more to fix this thing vs. just buying something else. Ugh.
ThatGuyYouKnow
I saw mention that the EverSolo DMP-A6 will be under $1,000. Is that correct? Seems too good to be true for all it offers, assuming everything works as expected.
hermano
What is the difference? They look identical.
multisport4me
Dunno what that will do to performance. I'm concerned about paying for something I don't need or will benefit from. (e.g. when Amir tests he tends to find factory input buffer/opamps measure better than any upgraded optional input buffer/opamps). If these are field upgradable I could always upgrade later if there is some empirical evidence proving there is a difference. I'm expecting this thing to perform very well aside from the "master" upgrades.
Purité Audio
Industry Insider
Barrowmaster
London
I have asked Misue at Eversolo, what the differences if any are.
Purité Audio
Industry Insider
Barrowmaster
London
See picture in my post above
I am just about to place an order with Eversolo, I haven’t been offered two versions of the DMP-A6 ( streamer).
Purité Audio
Industry Insider
Barrowmaster
London
Misue was kind enough to get back to me,
’ This model is Eversolo DMP-A6 Master Edition, a limited version with gold-plated appearance and some different components.’
I don’t think any more of these ‘special editions’ will be made.
multisport4me
:) They have promised me one.
They also said you'd be receiving a "regular" unit, not the "Master" edition....to which I'm happy to hear since the Master edition is very limited and soon to be unobtainium for us mere mortals.
I'm so excited to pair this up with Roon and have HDMI audio out. Toss is superb DAC performance (getting ahead of myself but these Sabre Pro boxes are hitting the ceiling consistently now) and this thing could really be a very nice value.
