- Joined
- Jan 15, 2020
- Messages
- 6,906
- Likes
- 16,960
Yes, as I wrote above the slope at the LP doesn't necessarily describe the perceived tonality above transition frequency.I tought we were talking about measurements at the LP position?
The recommended setup for Earl's constant-directivity waveguide speakers, and for mine (most of which use a non-axisymmetric device), is to use aggressive toe-in such that the speaker axes criss-cross in front of the listening area, and I can explain the reasoning if you would like.
Thanks for sharing those informations, can you guys also tell a bit more on why coherent wavefront produce a hole on axis and why aggressive toe in is better?the hole is a result of a very coherent wavefront emerging from the throat. That a different horn doesn't have such a null because the wavefront isn't as coherent doesn't necessarily mean the horn is superior.
that’s my experience as well. Still if all studios are using a flat target, you can learn to mix for that and it will be consistent. if people start to use a tilt provided by Sonarworks or similar but they do not agree on the slope we will not improve.
Yes, but as @thewas mentioned, the problem is that our ears/brain don't hear don't derive our perception of a system's tonality simply from the in-room steady-state. Instead, we tend to derive our perception of a speaker's tonality primarily from its direct sound at frequencies whose wavelengths are short relative to the room on one hand, and from the combined sound field at lower frequencies whose wavelengths are long relative to the room on the other.
For this reason, a flat in-room response will not have the same perceived tonality in Room A as it does in Room B (especially in the all-important midrange and treble).
When I said I found the uptake in use of target-curve based systems like Sonarworks to be a concerning development, it was for this reason. And that goes for systems that EQ to a flat in-room response and systems that EQ to some other (e.g. Harman-like) target; both are based on the same fallacy.
The graph from Genelec is for near field or far field? Near field, it should not matter much, reflections are usually very attenuated in studio (less so at home). Far field, for mastering, I agree. Mastering room are usually dead. Is controlling the RT60 enough to get consistent perceived sound?
I think he means this one this one which was taken at the LP of many studios, although we don't know at which distances that was and I think rather quite varying which would also explain the wide tolerance band.I'm not sure which Genelec graph you mean?
But yeh, that's a very good point. For less reverberant rooms and for nearfield listening, the difference between the in-room response and the direct sound is going to be much less significant than for more reverberant rooms with the listener in the farfield. So EQing to a target curve will be less of a problem in control rooms than in, say, a typical living room.
Guess the optimal way to approach in-room EQ would be to use room correction below Schroeder only, and if required do speaker EQ based on anechoic LW measurement above it.
Yes, but as @thewas mentioned, the problem is that our ears/brain don't derive our perception of a system's tonality simply from the in-room steady-state response. Instead, we tend to derive tonality primarily from a speaker's direct sound at frequencies whose wavelengths are short relative to the room on one hand, and from the combined sound field at lower frequencies whose wavelengths are long relative to the room on the other.
...I have now acquired measurements of the same system in different rooms with very different acoustic properties. What I see is the the tilt varies from around +5dB/close to flat in a properly treated quite dry room, +8dB in a untreated lager space, +12dB in a typical untreated domestic living room...
Would you mind posting more/making a new thread with this info?
Wonder why companies who have the means of doing the perfect (with a minimum of throat exit reflection) OS waveguide didn't do so and went with designs nearer to straigth or exponential slopes. I'm thinking anybody casting or moulding their front baffle (Genelec, Neumann, D&D, etc...).Ilkless explained it well.
Saying the same thing with different words: There will be a reflection around the mouth of most horns, unless the round-over is quite large. With a round horn, that reflection will all arrive on-axis at the same time (whereas with a rectangular or elliptical horn, the reflection arrives spread out in time somewhat - NOT coherent). So for a given on-axis listening distance, there will be frequency at which the mouth reflection arrives 1/2 wavelength later than the straight-down-the-middle-of-the-horn sound. And so in the general region of that frequency, you'll have some dippage. Typically the dip will be centered somewhere in between 5 kHz and 10 kHz, but it depends on the specific path lengths involved.
The solution Geddes recommends is to listen from about 15-20 degrees off-axis, where the mouth reflection is no longer coherent, and the dip disappears.
On the recommendation for aggressive toe-in with this type of loudspeaker, the main benefit is a much wider sweet spot. Briefly, the ear localizes sound by two mechanisms: Arrival time and intensity. With the aggressive toe-in, for an off-centerline listener, the near speaker "wins" arrival time but the far speaker "wins" intensity, because the listener is essentially on-axis of the far speaker but well off-axis of the near speaker. The net result is a pretty good soundstage even from well off to either side. The SECRET to this working well is, the output of that near speaker must fall off smoothly and rapidly as you move off-axis.
Take a look at the first photo here and you'll see what I mean. (Disclaimer: It's a photo of one of my systems at an audio show.)
To my knowledge the OS waveguide is designed for flat wavefronts, meaning a theoretically ideal compression driver. Direct radiating domes have spherical wave expansion, in which case a conical horn should be used (IIRC, of course). Neumanns waveguides look pretty much perfectly conical in expansion, which should be the "ideal" shape for the spherical wavefronts of their dome tweeters.Wonder why companies who have the means of doing the perfect (with a minimum of throat exit reflection) OS waveguide didn't do so and went with designs nearer to straigth or exponential slopes. I'm thinking anybody casting or moulding their front baffle (Genelec, Neumann, D&D, etc...).
By the way, since you seem to know a bit about the subject, do you have the answer to the question implied by this (https://www.audiosciencereview.com/...o-science-innovators.15025/page-2#post-472407) earlier post I made? Basically: were Genelec inspired by Geddes, or was the modern directivity matching waveguide developed in parallel and independently?It's always a juggling of tradeoffs. The Dutch & Dutch design was informed by Earl's work on the Oblate Spheroid, so there is some family resemblance. My guess is that adaptations were made to accommodate the non-flat wavefront of the dome tweeter, and to minimize the on-axis dip which has been mentioned. It looks to me like there might be a mild on-axis dip between 11 kHz and 14 kHz in some of the data, and that dip would move north as the listening distance increases, with its practical effect being correspondingly reduced.
The Genelec S360's waveguide looks like it could be an Elliptical Oblate Spheroid to me, which would have the advantage of having little or no on-axis dip in the response.
DIY Sound Group makes Super Elliptical Oblate Spheroid waveguides, which I've been using for years in some of my designs. Again, no on-axis dip.
