Ex Apple homepod designed launches 'triphonic' speaker
Kachda
NY
https://www.theverge.com/2021/5/17/...i-speaker-apple-designer-death-star-triphonic
McFly
NZ
So is an LXmini but its worshipped
Kachda
Kachda
NY
They are making very bold claims. But at $1800 for one this is way overpriced.
"Syng is making big claims about the spatial audio capabilities of the Cell Alpha. It’s styling it as the world’s first “Triphonic” speaker, because it offers spatial audio capabilities beyond the stereo audio that’s long been the traditional standard. In practical terms it’s supposed to allow the speaker to fill an entire room with surround sound audio, creating the impression that specific sounds or instruments are coming from distinct areas of the room. There are three microphones built into the speaker’s stand to measure the geometry of the space it’s in, similar to the HomePod, which helps it create the impression of surround sound using just a single speaker. "
jonfitch
How about just make a Homepod with Bluetooth and optical input and you can have my money.
mononoaware
Probability/chance drunk guest makes poor judgment and urinates into the Triphonic - 100%.
It even has alignment marking's for the stream.
I found this break apart image which is may be more interesting. . .
1621260493_356_Syng-Cell-Alpha-Audio-Speakers-All-Encompassing-360-Degrees-of-Sound.jpg
Second thought, someone may attach garden hose to the bottom of the stem/tube and use it as a sprinkler. . .
Sorry designer. . .
To be fair if the Apple HomePod was transparent it would be almost equal in looks (the stand/stem part makes the Triphonic extra funny looking).
mhardy6647
Looks like he left behind everything he had learned about design when he left Apple....
Looks kind of harman/kardony (or is that harman/kardonesque?) ;)
maybe with a little "soundsphere" thrown in?
As the author of Ecclesiastes put it
There is nothing new under the sun.
maverickronin
Midwest, USA
This. All you'd have to do is paint it solid white and would be as Apple as it gets.
Billy Budapest
Sorry designer. . .
“Lung?” Interesting nomenclature on that diagram.
Koeitje
RayDunzl
Central Scrutinizer
Riverview FL
Just look what it did to the cactus!
Soniclife
The way the stand attaches to the elongated pole piece of the bottom woofer is, interesting, as is the way it's designed to work in 3s.
mononoaware
Also. . . “Head sink”.
I thought it was “heat-sink”.
Maybe if they use words like “Lung” and “Head” referring to body parts makes it seem more “organic” and cool product and give the user something to “talk” about.
milezone
Seattle
That's a basic opinion... please elaborate? I personally don't like the incorporation of a pedestal/stem do celebrate (?) the design. I seems a bit antiquated or not well integrated. That said the speaker looks kinda cool. Sort of a hybrid between the HK Soundsticks and the Homepod concept as someone mentioned previously.
