Hey all,
Just opened up the Fiio BTR1K
https://www.fiio.com/btr1k
Upon opening the package I see the device which is the size of a thumb and made of metal. Upon picking it up, I can feel the build quality and the attention to detail. Using a original Google Pixel xl, it was easy to connect, the status light let me know when it is in search mode.
I plugged in my m50x's and turned on a playlist I use when I am on a bus or the subway. I flip through some rolling stones and fat boy slim to be greeted with a higher level of sound quality than I am used to on my phone. I get up and walk around my condo 900 sq ft with some concrete walls in the way and the sound stayed consistent the entire time with no studdering or drops that usually come with Bluetooth headphones. I walked to every corner and even down the hall with absolutely no issues. I then came back and watched some CES coverage and the video and audio is perfectly in sync as if I have that physical connection.
This one is a keeper when I upgrade to a pixel 3 xl.
