First Hi-Fi System
RickSanchez
Cartographer
Austin, TX
Set up on a 57 North Plank 42" walnut media console - $1130
  • Mostly solid walnut with some veneer
  • Cabinet for locking up mostly power supply / surge protector, but also open shelving to keep gear like the amp cool
You should add some budget for active cooling. Noctua fans are great, and there are pre-built solutions (cabinet fans / component fans) as well. If you're really pushing your amp I don't think that cabinet is going to offer you as much ventilation as you need.
A
ash87
How big is the room?
Depending on size, you might benefit from a sub or two.
Room is 12x20, with 8' open to a dining area on the long side. Couch is against the long wall with the opening.
I eventually want to add stereo subs. That's also why I was eyeing the miniDSP flex. I don't know a whole lot about room correction, but from the little Iv'e learned it makes a big impact when bringing subs into the equation.
A
ash87
I started looking at passive preamps from Goldpoint and Marchand. Digging deeper, I'm uncovering all kinds of details about input and output impedance, buffer stages, amplifier gain, DAC voltage out, etc. Most of what I find online distills down to "passive preamps are great in a well designed system", mostly about having a low source output impedance and a high amp input impedance. The Modius outputs 75 ohms and 4 volts, a passive preamp may have a 10k or 20k resistor, and the hypex has a 1.8k ohms with 26 db of gain.
If source to amp impedance needs to go low to high 75>10k>1.8k doesn't seem like a good idea (sans a buffer stage).
Whereas something like a Schitt Aegir at 22k makes more sense.
Please feel free to chime in or point me to some literature on the topic. A common dismissal of passive preamps is that they don't sound good with longer interconnects.
NTK
US East
... the hypex has a 1.8k ohms with 26 db of gain.
Input impedance is 100 kohm. The 1.8 kohm input impedance is for the unbuffered input of the UcD180 OEM version, which is different from the one in the Hypex DIY kit (UcD180 High Grade Version).
[Edit] The worst case output impedance with a 10 kohm pot is when the wiper is at the middle (when ignoring the 75 ohm output impedance of the DAC). The source impedance at that point will be equivalent to two 5 kohm resistors in parallel, which equals to 2.5 kohm. It is well under the recommended source impedance of 7 kohm, so I think you are safe.
A
ash87
Ok, that makes sense. Thanks. I was looking at the stepped attenuators from Goldpoint, they offer custom resistance values. If Hypex recommends a source impedance of 7k, would it make sense to choose a 10k Goldpoint attentuator?
NTK
US East
Sorry. What I should have said is the Hypex recommended maximum source impedance is 7 kohm. The Goldpoint 10k attenuator should work, but IMHO, unnecessarily expensive for a simple job.
A
ash87
Hey ASR,
Just want to say thank you again for all the input and info on this thread. It's been a long time coming but I am finally sitting here listening to music on my very first HiFi system for the very first time.
Raspberry Pi 400 running Volumio & streaming Tidal Connect Hifi> Schiit Bifrost 2/64 > Topping Pre90 > VTV Purifi 1ET400A w/ stock Hypex buffer > Focal Chora 826 (Everything plugged into a ZeroSurge 8R15W-I)
I'm still unsure what to make of it. Never really went to a dealer to listen to other systems, or have any friends who are into this, so I don't have a baseline reference to compare it with. My overall impression is that it's OK/decent. It doesn't feel like anything magical the way I imagined, if anything it's feels a bit harsh on my ears, like they kind of hurt at relatively modest volumes. I didn't really play with speaker positioning too much.
I don't speak audiophile, but is the pain/discomfort in my ears what is considered "bright"? It's just doesn't feel easy to listen to.
Thanks
