First Impressions of the Magnepan LRS vs. the LRS+
PJ2000
After months of waiting, I finally received my new LRS+ this week. I had a chance to do some very preliminary listening and testing. These are my subjective opinions and should be taken as such. It would be hard to do a blind test as these speakers sound different enough that you could identify which was which. Since this is a hobby, I would suggest that you try it out yourself in your own environment. These speakers haven’t been ‘broken in’ and it will be interesting to see how much the sound changes over time.
Summary: The LRS+ isn’t a slight upgrade, it sounds like a different and better dipole speaker than the LRS. Yes, the LRS+ overall has the typical characteristics of a dipole speaker of that size, but it is significantly better on a few dimensions. Detail: The LRS+ has much better detail and where I least expected it. Oddly enough it’s bass response is audibly worse (measurements confirm) than the LRS, but the detail is much better on complex passages such as drum rolls. Realism: It sounds more ‘real’ than the LRS and the LRS was really good at that. Where I hear the most difference is on vocals (male/female) and acoustic instruments such guitar, violin and cello. Delicateness: I don't know that this is a thing, but it has this ability resolve really tiny things like ambient sounds, breathing. I don't know how to explain it. Soundstage: The LRS+ sounds a little more focused than the LRS which might also lead to sounding more like ‘live’ music. To all the LRS owners out there, I think the upgrade is significantly better than the price differential. If you would like more details, keep on reading.
Testing Setup:
Amplifier: DIY Purifi 1ET400A, Reference design in Low Gain Mode
DAC: SMSL DO100, balanced outputs
Streamer: Volumio/Tidal
Fit & Finish: While these speakers look perfectly fine, they don’t have the same fit and finish of the LRS. I suspect that they reduced the manufacturing cost of the speaker with some of these changes that are largely cosmetic and invisible at listening range. For example, the edges aren’t rounded and the side trims are gone. Since the sock material is black on mine, it doesn’t make a big difference visually.
Stands: I think that one of the issues that has lead to poor sound from the LRS’ is the crappy stand that they ship by default. I spent months tweaking location angle etc of my speakers until I saw some reviewers talking about third party stands such as Magna Risers and what difference they made. I decided to test out the concept by using some cinder blocks and I was shocked how much better they sounded. I ended up getting the Magna Riser MK7 multi-riser and I use the highest setting on it. For this comparison since I didn’t have two of those, I used cinder blocks and the stock stands so I could quickly switch speakers. If you own these and are using the stock stands, I guarantee that if you raise them and change the angle to 0 degrees, they will sound much better. If you have any doubts on that, Magnepan has been shipping the LRS+ with the raised stands to reviewers and at demos. It’s a night and day difference. If you don’t want to spend money on commercial stands, you can easily make your own ghetto stands, for under $10 (see picture). It is a waste to listen to these speakers using the manufacturer default stands.
Room: These speakers really need a ‘medium’ sized room. If your room is too small or too large, since they use your walls, and placement is important, they can easily sound bad. You must be willing to spend some time experimenting. Unlike standard speakers, dipoles, for obvious reasons are very room size and placement dependent. If you don't have the right room, these speakers also can sound pretty underwhelming.
Position: About 32” from back wall with tweeters on the inside angled at about 35-40 degrees.
Measurements:
I have Sonarworks SoundID Reference, so I used that for the in-room measurements. Each composite is comprised of about 40 measurements centered around the listening position. You can see the uncorrected in-room response plots below. They are quite different and some of the differences such as low end are quite audible, but the others aren’t as obvious to me. The room is not symmetric, and the left has a full corner while the right has a corner is mostly a cutout. That is why the low-end response is better on the left vs. the right. I measured the LRS+ before I listened to it and therefore expected the LRS to sound better than the LRS+. I was honestly a little disappointed after I saw the measurements before I listened to them. The feeling was a 'much ado about nothing' because of the reviewer hype.
LRS:
LRS+
Methodology:
The assumption was that the speakers were identical and were measured/listened from the same position of speakers and listener.
Low end:
  • 40Hz test tone: The LRS+ was about 4db lower than the LRS under identical conditions. This is very easily audible.
  • Poem of Chinese Drum: This is a wonderful piece for testing your speakers. In my small room the LRS has always had enough bass for the tracks I listen too and this piece sounds very good. The difference with the LRS+ was very surprising. It’s detail was significantly better and in many rolls you could now hear that they were made up of more than one drum at the same time. The LRS in comparison now sounds ‘muddy’ even though the low end response is significantly better. One of my concerns is whether this is actually a ‘breaking-in’ phenomenon and whether the LRS+ will also loose detail as the mylar film stretches. I plan on keeping my LRS for a while so I can redo these tests in a few months and update the results. On the downside the difference in low end is high enough where you might consider a subwoofer mandatory.
General observations on a few selections:
  • What a wonderful world (Knopfler,Botti): MK’s voice sounds clearer and fuller
  • Sarsate:Carmen Fantasy (Mutter, et. al): The violin sounds amazing and live. Clearer in detail and space
  • Goodbye Yellow Brick Road Live(Bareilles): Smoother voice and more ‘precise’ soundstage
  • The Parting Glass (Wailin’ Jennys): Smoother voices, better separation and focus of singers
  • Beethoven: Triple Concerto (Mutter, Ma, Barenboim): More focused soundstage
  • What a wonderful world (Melua,Cassidy): Smoother voices
  • Sweet Emotion (Aerosmith): That triangle or something sounds clearer about 2/3rds in
  • Homemade Ice Cream (Tony Joe White): Harmonica is clearer and sounds more ‘live’
Obviously, I was surprised by the difference between the measurements, what I expected and what I heard. I haven't spent any time treating the LRS+ as a different speaker and optimizing its positioning. That is next on my experimentation list. Let me know if any other details or experiments might be useful.
Happy Listening.
Spkrdctr
Hey, if you like them and they make you happy, that is fantastic! Enjoy your new speakers and I would recommend you add a sub as you said, it is probably mandatory. Thanks for the review of your experience with the speakers.
I have just got my LRS+ set up and I am really enjoying the spacious sound I have so far. I have a set of the Magneriser mk7 on order. The only thing that I regret is when I got my speakers they were the off white finish instead of the black ones. I have 1.7 and mgmc in black so they are not going to match. Mine are 34 inches from the rear wall and the tweeters are 83 inches apart. My ears are 100 inches from the tweeter give or take in my seatings position . I have replaced the metal jumpers and replaced it with solid core wires ( copper).
Mario Sanchez
My local dealer just received them, will give them a try later this week or the next. This might just be my first entry in planar speakers. Would be cool to have paravents that can play music in the living area.
Edit: Typo.
ripmixburn
Toronto, Canada
Edit: Typo.
Sounds like they are back-ordered for over a year, so if you like them, I would grab them!
davlynam
I have my Maggie .7's on Mye stands, about 3' off the flr (going to experiment with Isoacoustics feet to get more elevation) 40 degree toe in, Cardas jumpers, Acme Labs replacement fuses, and JL dual subs. Each step resulted in improvement.
ripmixburn
Toronto, Canada
Are there any binaural recordings of the LRS+ in the wild? Even a Sennheiser AMBEO Smart Headset (clearance prices) would give some indication.
RobL
What improvements did the jumpers and fuses give? Do you have measurements?
I have the 1.7 and the LRS + and I have replaced the steel jumpers to a small piece of solid core OFC speaker wire and at seems to sound better in the high frequencies. It might be psychological but I enjoyed the experience.
cabs84
i've been enjoying my LRS for the last year, but wish i'd waited to get these after hearing that they have even more detail and top end. (i hated the lack thereof of the top end in mine for the first two months of ownership, and i chalk that up to either the need for the mylar to stretch to its settled tension and/or placement)
i've been looking at building a kit of philharmonic BMRs as my next speaker. after that i might just pre-order the LRS+
Haint
Based on the OP's measurements, it seems likely the increased "detail" is actually the significant reduction in Sub-400Hz output also reducing the masking effect. That is, more output in this bass and low-mid-range region will tend to cover up higher frequencies (i.e. they don't stand out, or we don't hear them as well). Problem is everyone likes bass (including golden ear audiophiles), so if OP's measures are at all indicative of anechoic performance, I wouldn't expect the Plus to do very well at all in a blind preference shootout (not just against the LRS, but any other speakers in general). I have some smaller sealed speakers that are flat to like 120Hz then drop of a cliff, and while they do indeed sound more "detailed" when played alone, they simultaneously sound anemic.
cabs84
that might be part of it - it does look like the plus have their last peak much nearer to 20khz before dropping off a cliff - the original look closer to 15khz at least in the measurements above. not that i can hear far beyond 15-16k at this point
Robert
Testing Setup:
Measurements:
LRS:
LRS+
Methodology:
Low end:
Happy Listening.
The LRS+ graphs display inferior linearity of the frequency responses across the board and more rapid dropoff of mid-bass relative to the LRS. This is contrary to what would be expected from the list of highly favorable subjective phrases in the review, which appear to be a combination of confirmation and publication biases. According to measurements and through-the-sock views, the LRS+ differs little physically from the LRS, except slightly in width and available in fewer colors. I believe it is likely that the new model was introduced to incorporate cost-saving materials or manufacturing methods and to raise the price significantly, especially with upsale of very expensive optional taller stands.
ripmixburn
Toronto, Canada
Where are these graphs you speak of?
Robert
First post on this forum dated October 22, 2022, here:
All I know is that I don’t listen to graphs. My LRS + make me enjoy the music and I feel that I am immersed in sound, not like a headphone. Every instrument is a correct proportion and except for the lower frequencies it works well in my room. It is not the best I have ever heard but it is the best I’ve heard in it’s price point and probably twice it price. While listening to some recordings it presents an image far from the edge of the actual speaker, the better the equipment the speakers have also improved the sound. As I updated my DAC and amplifier the resolution was much better. I think the speakers were tested before they were actually broken in. They are also very placement sensitive and if you are off axis you can definitely tell it.
