FLUANCE TURNTABLE SPEED ADJ
EBBOY
having trouble adj. speed on my turntable any hints on this getting screwdriver seated properly etc. like this turntable but
mhardy6647
Which model? There are (or have been) several. EDIT: Looks like they're all basically the same.
I found this on their support page:
My guess is -- make sure you're using a good quality screwdriver of the right size. I like the Wiha screwdrivers for stuff like this.
This (EDIT: i.e., ASR) is a kind of funny place to ask ;) -- you might want to try somewhere like the "vinyl" forum at audiokarma or audioasylum
Chrispy
PNW
This is a kind of funny place to ask ;) -- you might want to try somewhere like the "vinyl" forum at audiokarma or audioasylum
It is in the appropriate area of this forum....
I never liked the adjustments for belt drives, why I went dd back in the 80s :)
Golf
Reading this makes me feel that there are a lot of other things which have to be adjusted, prior to any TT speed.
Chrispy
PNW
Another question, how are you measuring accuracy and/or why are you needing to change speed?
morillon
in your case...better is use stroboscope solution.....
(old incandescent lamps work very well...no need for a halogen , that s better make it in playing with paper strob , very light...etc)
