Focal Alpha 65 EVO Review (Studio Monitor)
Rate this speaker:
    Votes: 12 3.7%
    Votes: 42 13.1%
    Votes: 206 64.2%
    Votes: 61 19.0%
bennybbbx
germany
it seem important that use the rubber feet that they stand on the wooden case and not on the plastic on side. wood and plastic have diffrent tenperature coefficient so they do sometimes click when temperature change. on my speakers the wood case is 2 mm higher as the plastic and when the rubber feet is not used the plastic is sit on stative and the wood of the box have no contact to stative. not easy to explain.
In the focal manual stand that the alpha evo speakers should position from 40 cm - 3 Meter away. so i put them 55 cm away and measure on both kali and focal step response. there can see focal faster rise time. better can see in 1.5 cm away bass/woofer step response. that some part hold the 100% is good because the perfect step response should look as a rectangle. on the 55 cm distance the focal have strange step response. there come first a negative impulse later the postive from tweeter. but also focal faster. maybe they sound even more better when they are better https://audiojudgement.com/loudspeaker-step-response-measurement/
time aligned.
tomtoo
Germany
Sry, but i dont see any biger difference in timing of woofer.
And thats worst case, how look the 104?
tomtoo
Germany
But what realy is mind blowing. How can a speaker has more distortion at lower level?
dfuller
As has been stated earlier in the thread: Focal thinks it's a defective tweeter. Amir has a replacement unit in for testing at some point.
Don't encourage him.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
you ask wy 5 khz are not enough. i do many tests with 6.5 inch kali lp6 speaker. in this example
We aren't doing this again...
Please don't keep starting this up at every chance.
heflys20
LOL! Anyway, whatever happened to Focal sending a new speaker?
Edit: Never mind I see he received it and needs time to test it.
dfuller
YARE
Don't know when the test of the newly delivered Alpha 65 Evo will be?
There "will be" a test if someone sends him a unit or simply buys him one, else you won't see any Alpha 80 Evo's tested.
dfuller
Amir got a second unit from Focal to test because of the anomalous distortion behavior.
dfuller
YARE
Nobody was asking about the Alpha 80.
"that comment says 65 for me", you can edit btw.
It was definitely a typo.
xaviescacs
La Garriga, Barcelona
I needed some active speakers for my living room, for the TV really, and bought the younger brothers of these, the EVO 50, by 450 € the pair. They are driven by a Sabaj A10h. I must say they are wonderful. I've set -1 db for highs as they are a bit too much for my taste, and -2 db for bass, just to follow that rule of the rear wall, more or less. I hate uncontrolled bass, and I must say these monitors are very good in that regard. With them, orchestral music feels very natural, and the double basses sound like they should and not like electrical amplified basses. Timpani sounds very clear too. I would describe their sound in my ~ 25 m² living room as very clean, without artifacts, at least for my untrained ears. Before I've had a pair of floorstanding audiovectors in the same room and in comparison they sounded as if the sound was reflecting everywhere, bringing more energy but not much more clarity than the built in speakers of the TV. With the EVO, it's night and day. Really happy with the purchase. Thanks ASR, again.
At long last, I managed to find time to test the new factory sample of Focal EVO 65. I am pleased to report that the distortion I saw at 86 dBSPL is not there:
On the left was a repeat of the measurement on sample #1 to make sure I could repeat it. As you see, I did. On the right is the new factory sample and it doesn't have this issue at all. I will be sending my sample to them for investigation.
I edit the review and upgraded the rating for the speaker. Seeing how quickly and positively the company responded to my testing, I am doubly impressed with this speaker and company.
It was such bad timing. Our home flooded right after I received it. Then my speaker measurement space became plumbing central to deal with the flood. Was going to test it a couple of weeks ago but then we flooded again. I still can't walk through the space but could do the distortion test and hence above. My apology to you all and the company for not getting this done sooner.
