Focal Alpha 65 EVO Review (Studio Monitor)
Rate this speaker:
    Votes: 12 3.7%
    Votes: 42 13.1%
    Votes: 206 64.2%
    Votes: 61 19.0%
Merkurio
Great results.
I hope you review the Alpha 50 in the future to see how it compares with the Adam T5V!
thewas
I wonder why there isn't an Alpha 80 Evo
Probably because many 8" drivers can be quite compromised as midwoofers and also Focal prefers wide radiation designs with tweeters with no or shallow waveguides and there a large midwoofer would not offer the needed directivity at the mids.
pierre
Switzerland
Sure, the newer ASR measurement of the EVO has more points/less smoothing than the older one, but the weird tweeter behaviour is unacceptable and does not give trust in the engineering and long time quality of the monitors and unfortunately matches also reports with reliability problems with other of their active monitors and headphones.
For active monitors, do you have data? Focal Solo or Trio have been very reliable for me. I would be interested in failure rate of monitors over time but I am guessing that’s not public data.
thewas
Wish I had, just what I am reading in various forums, mind you that might not account to all models or series and possibly just more to their cheaper series.
ShiZo
Are these better than jbl 305s? Do they have the Twitter hiss?
FeddyLost
The tweeter distortion results is really interesting. Would love to learn of the reason behind it
Looks like some weird crap is going on within HF amp section. Something is generating high order harmonics with constant absolute level, so they are relatively small with higher signal.
Tweeter itself most probably working well, as most drivers start from 2nd harmonic, as woofer on these graphs. For getting domination of 4th and 5th, one need to go beyong decent driver in its comfortable range (86 db for typical tweeter is milliwatts, so it's barely motor issues).
They have almost no hiss which makes them much better than 305. They also play louder with more bass.
GWolfman
Preference Rating
SCORE: 4.1
SCORE w/ sub: 5.9
Surprised it scored this low.
Also surprised the front port didn't cause more cancelation issues as most do. Why do you think this one managed so well in this regard?
Last surprise was the low-frequency extension they managed to get out of this.
Newman
The mystery of the tweeter distortion needs to be solved.
Product issue (if so, what)? Or test issue?
I think this is because the predicted-in-room response is almost flat. If you turn down the HF adjustment, it would fix that and increase its score substantially.
3125b
Germany
Confirms to me what I always thought: Focals sound better than they measure.
I did a blind test of different active monitors when my dad was looking for a pair and, despite hearing some more expensive models, he settled for first gen Focal Alpha 65 and I have to agree with that decision. I‘m sure those don‘t measure very good either but they are enjoyable for music listening.
Yes they are.
It‘s really not a fair comparison, 5“ 110$ budget monitors against something twice the size and more than double the price.
I‘ve tried the first gen Alpha 65 next to my Mackie MR524 (comparable the the JBL in size and price) and subjectively there is a big difference. Although the MR524 have one advantage over both the JBL and the first gen Alpha (Class AB amps) - much lower tweeter hiss, they are among the quieter active monitors I‘ve heard.
Matias
São Paulo, Brazil
This is good, but Kali LP v2s are still better.
Pearljam5000
But there's a non EVO, Alpha 80
MZKM
Land O’ Lakes, FL
Yeah, they go for constant directivity in the treble where tweeter response mainly just lowers in level as you go off-axis rather than slope down.
Interestingly, Charles Sptinkle said he stopped designing his waveguides for do that when he went from JBL to Kali, as It can lead to brightness.
