- Joined
- Feb 23, 2016
- Messages
- 20,828
- Likes
- 37,754
The specs show the same gain for both inputs actually. Just different input impedances. If true and not a misprint, you'll be running gain quite low, but have plenty. Output can be up to a bit more than 4 volts. You should need only 22 db from 300 mv to reach about 4 volts out.I bought a Cambridge Audio Duo based on the review posted here on ASR. However, it has a nominal output of only 300mV, which is why I wondered whether the extra gain with XLR in could be useful. But I guess I'll use TS adapters and adjust the gain manually, using the knobs on the front then.
Most of these lower cost interfaces use the same gain circuit for line and microphone input. They just pad the line input down and raise the impedance. I guess in the case of the 2i2 as a cost saving measure they just changed the input impedance.
