Follow Up: Puffin Phono DSP Preamp
watchnerd
Seattle Area, USA
It's probably those cheap toslink cables...
Feel free to wax eloquent... I'll do some blind comparisons when I get mine, because I care.
Is there a record that is going to be the standard if we've got a few of us sending in rips/samples? Is there a way to legally share rips with others, if they own the same record?
Don't want to get anyone in trouble, especially since I'm supposed to be the responsible one...
I did Side2 of DSOTM as my first rip (out of the 8 billion available versions/pressings) with the VM540... Turned out surprisingly well (IMHO), but I've got to dial in the process if these are going to be compared.
Ready for some blind comparisons?
Puffin scenario:
TT -> Puffin -> optical out -> Devialet optical in -> Devialet USB out -> Macbook
Gain: 68 dB
Loading: 200 ohm
Optical cable: Fancy looking Monoprice cable, 10 feet
All special effects, Magic, etc, off.
Devialet scenario:
TT -> Devialet phono in -> Devialet USB out -> Macbook
Sens: 0.25mV
Loading: 200 ohm
Stage A Listening Test:
https://drive.google.com/file/d/1iE-3F9dDdHdh-jiA8DdAFHL8sA-kGkVA/view?usp=sharing
Stage B Listening Test:
https://drive.google.com/file/d/1S6P3OoggI_8v0pnKg_75F_WwrI_PxcDM/view?usp=sharing
If Audacity is right, the level matching should be pretty close.
watchnerd
Seattle Area, USA
BTW, here are my ABX results from comparing the two files:
So 80%.
But also only a test of 5.....so could easily be just luck.
On the other hand, I was listening through laptop speakers...
nagster
Too bad this does not come with USB output. Would be a perfect tool to digitize records. I am aware of the spdif option, but that spdif>usb conversion.
The RME ADI-2 DAC in your signature may be able to send the S/PDIF input to your PC via USB.
Last year's post ...
