Use the zoom function in your browser? The design seems to scale well, so I see few issues with that. Hotkeys in Firefox and most other browsers on Windows would be Ctrl-+/- and Ctrl-0 to reset.
<meta name="viewport" content="width=device-width, initial-scale=1">
Huh. ASR (at least this very page we are on) uses a bog standard choice of "viewport" meta tag, the common
Nothing that should prevent you from zooming, like the attribute user-scalable being set to 0 / no. So I'm at a bit of a loss here.Code:<meta name="viewport" content="width=device-width, initial-scale=1">
In this respect, ASR should behave like a gazillion other websites, including mine. Is that any different? Might be worth checking out with another browser app.
FWIW works fine on Firefox. In order: normal, pinch zoom, accessibility 200%:
Just gonna report that Safari on iOS works.Below is what I'm seeing from ASR with Chrome accessibility font zoom set to 135%:
It's maddening small and doesn't change even when I max out at 200%
Below is a screenshot of a random page on your website. Your website respects my Chrome accessibility font zoom settings
I can really crank your fonts up when I set my zoom to 200% (below) if necessary:
I've tried 3 different browsers, Microsoft Edge, Chrome, and Brave. ASR ignores the font size zoom settings of all three browsers. It looks like ASR, like a few other forum websites, just isn't optimized for mobile.
I tried Chrome on iOS and it didn’t allow text zoom at first. However, requesting the desktop version then allowed text zoom to work. Weird thing is, I can request mobile version and the zoom option still is active.
Both ASR and head-fi use xenforo, so it might be a bug there. Their forum also doesn't scale. But what is more probable, is that the actual text scaling feature in chrome is buggy: Issue 779409: Text scaling setting in Chrome scales some elements but not others. For example, go to https://google.com and you'll see it is also not scaled.Head-fi was another forum that wouldn't play nice with Chrome accessibility settings.
The point of google.com example was that if even google's own pages don't scale, then it is not a problem with those different sites but with chrome itself.No need for me to go to Google com. I can already see the variance in font zoom right here on this page.
Try Brave browser which is chrome based and see if it works differently. Just to see where the problem might lie.
Well maybe Firefox will do it for you.Already did. Same result...because it's chromium based. Microsoft Edge is also chromium based and also can't adjust in-line thread fonts on ASR. So I think we've found the common denominator.
Actually it works for some thread topics for me, but not all. But it works for all messages content.Doesn't work for me. You're probably referring to desktop browsing. I'm using Chrome on Android mobile. Adjusting the Chrome zoom setting to max, which is 200%, has no effect on ASR. I was hoping there was a Don't size setting for ASR like there is with Twitter.
