digitalfrost
Download: https://www.foobar2000.org/download
Release notes: https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Version_1.6_Release_Notes
Version 1.6 overview
This is a major update introducing new features and functional changes.
Compatibility
Windows 7 or newer is required, with a processor that supports SSE2 opcodes (anything made during the last 15 years should do).
Windows XP and Windows Vista are no longer supported.
1.5 series supporting these operating systems will be kept available for download indefinitely. Also, important bug fix updates for 1.5 series will be made for as long as people care to report bugs.
Notable new features
Compatibility
- New default WASAPI output.
- Output-independent implementation of clickless fading (same as in current foobar2000 mobile and foobar2000 for mac).
- Out-of-the-box 7zip archive reading (Archive Reader component included with setup).
- WebP cover art support.
- New Unicode-based filename character substitution in Converter & File Operations.
- DirectSound output (replaced by WASAPI)
- Removed obsolete edit-replaygain-info menu command since Properties dialog does the same now.
- Windows volume mixer integration (buggy, rarely used).
