Fosi Audio K5 Pro Gaming DAC/AMP Review
nightlite
There is a severe lack of good DAC/AMPs with a decent microphone input on the market, there are a lot of cheap dongles and no-name soundcards, but nothing that stands out.
If your using a Gaming Headset which probably costs like 100-200€ you will have a hard time finding a soundcard or DAC/AMP which doesnt break the bank. There are some more expensive options from Schiit (which is a lot more expensive in europe than in the US), Creative or Epos, but in my opinion they are simply too expensive, the audio device in wich you connect your headset to shouldnt be equally or close to the same price as the headset you are using.
When I saw the Fosi K5 Pro it seemed like the holy grail, a device which has a solid metal build, no software shenanigans, mordern USB-C input, good audio for headphones, a mic input and is also affordable? (72€ on Amazon Germany, 59$ on Amazon US right now) Seems like it´s too good to be true, but I instantly ordered it to give it a try.
Microphone Input
The Mic input is the first thing i tried when i got the device. 3,5mm mic inputs are really bad on a lot of audio devices, so if the mic input wouldn´t be good on the Fosi K5 Pro, it would not be worth purchasing.
I tried the V-Moda Boom Pro and the ModMic v4, with 100% mic volume in windows, both of them got pretty loud, very close to 0dB. I also tried the Mic of the Epos/Sennheiser PC38X, it was a bit quieter (about -20db to-10dB), but thats still very loud and a lot louder than a lot of gaming headsets (for example: my Astro A50 Wireless Gaming-Headset only gets to about -25dB of loudness).
I am very happy with the quality of the mic inputs and I also didn´t hear any noisefloor with the mics. There probably is one, but the fans of my PC are louder :). The only time i heard the noisefloor was, when i physically muted the mics (by lifting up the pc38xs mic or pressing the mute switch on the other mics).
Microphone Crosstalk
Crosstalk is an often overlooked problem with gaming headsets. Because most gaming headsets will use a shared ground for the microphone and headphones, you will usually have some crosstalk, meaning that the mic will electrically pick up whatever you are listening to on your headset. There are hardly any headsets out there, which dont use a shared ground for mic and headphones, the few execptions i know of are the Beyerdynamic MMX300 and several Epos Headsets (the PC38X for example). Soundcards/Dongles with a TRRS combi jacks will usually also add some crosstalk to these headsets, because they will connect the grounds.
The Fosi K5 Pro has seperate jack for headphones and mic, I tested it with a modmic v4 and a Sony XM3 Headphone (using wired connection) and got no audible crosstalk.
I got a bit of Crosstalk with the PC38X (it has 2 ground wires, but they are still in the same cable) but it was very low (around -50dB). First I couldnt determine if it got picked up elctrically or acoustically by the open back design of the headset, but when muting the microphone by flipping it up, i could still hear the music in the recording, so it was probably crosstalk caused by the cable. But as I said, it was really quiet and shouldn´t be a problem.
Microphone Monitoring / Sidetone
Mic Monitoring can be activated in the Windows Audio settings, it works great and without any perceivable latency. Nice. :)
Build Quality
Pretty much what I expected. A solid metal build, no other gaming-soundcard in its price range comes close to it, I´m really happy with the build quality.
The Knobs
The Knobs feel like high quality knobs, i have no complaints here. However, using the knobs is another thing, it simply doesnt feel good. The reason for that is, that there are 3 knobs which a very close to each other, so there is very limited space for your fingers to properly turn the knobs.
The Bass/Treble knobs have kind of a snap/notch at the neutral position, meaning they will kinda snap into it, they also affect both the frequency response of the headphone out as well as the line out in the back. For me personally its an unnecessary feature, i would prefer to only have a volume knob to have more space for my fingers when turning it. Maybe its nice for console players to get some way to use a bit of EQ, but PC players can just use software EQ which is a lot better.
The Cable
The cable is a USB-C to USB-C cable, on one end it has an attached USB-C to USB-A converter. That added converter is really nice and ensures, that you can connect the Fosi K5 Pro to most devices out there. The quality of the cable is nothing special tho and its also really short (its about 1m long), I guess there will be a lot of people out there which will have to use/buy a longer cable to connect it to their PC.
Line Outs/Pre Outs
The unit has 2 RCA outputs on the back, which are constantly on and are controlled by the volume knob in the front. I think most gamers would probably connect their speakers to this outputs.
In my opinion there are only 2 behaviors which are suitable for using speakers: The first one is to have a constant output in the back, which isn´t controlled by the volume knob in the front, so you can connect an external volume knob (or use the knobs on your speakers) to control the volume. The second one would be to have the line outs controlled by the volume knob in the front, but automatically mute whenever you connect your headphones to it.
Sadly, Fosi chose the worst approach for this, so using speakers with the DAC/AMP isn´t really ideal. Because the line outs are constantly on and controlled by the same knob, it forces you to unplug your headphones everytime you use your speakers (to make sure your not sending in too much volume in the headphones and potentially damage them) and also forces you to turn off your speakers whenever you are using your headset/headphones (if you dont turn them off you will have audio from both devices at the same time).
The Power LED
The device has a blue shining LED which lights up when the device is powered on. It also shows which input is selected. The LED is too bright and could possibly be distracting for some people.
Power On / Input Switching Behavior
Pressing the volume knob long will power on/power off the device. Pressing the volume knob shortly will switch through the inputs. Switchting through the inputs also feels really fast, there is hardly any delay.
The device will not automatically power on or off with your pc, you will have to do that manually. The device will also not remember the input selctions after being powered off, it will reset to USB input every time you power it on. In my opinion thats not that great, most gamers would probably prefer to have it automatically power on/off with their pc. It would also be nice if the device would remember the last chosen input.
Powering the device off will disconnect the USB-device from windows, switching the inputs will not disconnect it. In my opinion thats really nice, so you can still use the Optical/Coax input for listening while sending the Mic input to your PC over USB.
Headphone Output Power / Noise Floor
This device easily powers every gaming headset I own and also has no problems with headphones which require a bit more power. The lack of a gain switch makes the amp almost too powerfull for typical gaming headsets, my PC38X and Coolermaster MH751 are already really loud (about 80dB) at about 10 o´clock on the volume knob. The Noise Floor gets audible at around 15 o´clock on the volume knob (which would be way too loud for regular use, my MH752 gets about 110dB loud on that volume setting).
This is especially appearent when you use IEMs with it, they are already loud enough for me at around 8-9 o´clock, if I lower the volume a bit more, I can hear the channel imbalance of the analog volume knob. I also didnt hear any audible noise with the IEMs. I can only hear noise with IEMs when i turn up the volume to around 13 o´clock, but that volume would probably deafen me if I played any sound.
So the range of volume control is quite limited with sensitive headphones/IEMs. You can counter that problem by lowering the digital volume on Windows, however you will have to turn down the windows volume a lot (to around 10-15% to get a „good loud“ volume at 12 o´clock on the volume knob), but thats also very close to the audible noise floor for IEMs. So the device isnt really suited for IEM usage.
Headphone Out Audio Quality
So how does the Fosi K5 Pro Sound? I compared it to my SMSL M200/SP200 Stack, mostly using the Sennheiser HD560s for comparing them. The sound quality of the Fosi K5 Pro was a bit lacking, the Bass was lacking and in general the sound was a bit lifeless.
Im not a big believer in DAC/AMPs sounding different and think its just placebo, if its not measurable, so I volume matched the SMSL M200 DAC and Fosi K5 Pros Line-Outs as well as I could and connected them both to my SMSL SP200 amp. That allowed me to use the input switch to instantly switch between the SMSL DAC and the Fosi K5 Pro DAC. My conclusion was the same, the SMSL DAC just sounded better.
After that, I used the front Line Inputs of my Audient EVO 16 Interface and the software „REW“ to record the frequency response of the Fosi K5 Pro with the bass and treble knob in neutral position. I´m not the most expierenced when it comes to measuring stuff, so take my measurements with a grain of salt. I also measured my other DACs with the same setup (the input signal came from the optical output of my Audient EVO 16 interface) to have a comparison.
Fosi K5 Pro Line Out Frequency Response:
You can see, while my other DACs measured pretty much flat, the Fosi K5 Pro nearly drops to -4dB in the bass and down to -2dB in the treble. That could explain the differences i heard between the devices. @Fosi Audio is the frequency response of the K5 Pro supposed to look like that, or did i get a faulty unit? Or did I do a mistake while measuring it?
I also made a measurement of the headphone output, and compared it to some of my other AMPs (SMSL M200 was used as DAC for SP200 and Ifi Zen Can):
Since I was already measuring frequency responses, i also measured the response of the bass/treble knobs. Here it is in maximum and minimum setting:
Here are measurements of the bass knob in various positions:
And here are measurments of the treble knob in various positions:
Conclusion
I´m disapointed. The device has great microphone input, good build quality and the right price, but sadly the audio quality is lacking. Also the usability could be a better.
My suggestion to make the product better: Make it sound better (obvious), remove the bass/treble knob and add a gain switch. Also change the device so it automatically powers on and off with your pc and make the RCA output on the back more usable. Either by adding an output switch to toggle between headset/speakers, or change the behavior of them in one of the 2 ways I mentioned above.
staticV3
Thanks for the review!
Bass/Treble knobs are often more trouble than they're worth. A complete no-go without a tone defeat switch imo.
Since the DUT is USB-powered, this is down to your PC, not the DAC.
If your motherboard shuts down the +5V supply when you turn off the PC, then the fosi will turn off as well.
If the USB ports remain active, then the fosi stays on.
It's laughably obvious why Fosi called this device "K5 Pro" :rolleyes:
nightlite
nightlite
Yes, you are right. I´m actually aware of that, I should have mentioned that in the review. :)
But I also had some PC peripherals, which automatically turned off (or went into standby?) when the PC was shut down, even if the USB port still delivered power (the elgato stream deck for example).
Pixol
For what its worth, the first K5 Pro I ordered from Amazon in November sounded pretty weird and harsh. The optical and coaxial inputs sounded horrendous. Also, the DAC only supported 48khz 24 bit and higher, which made "bit perfect" music software non functional for certain sampling rates and bitrates, like CD quality. However, I left a bad review on their Amazon page and Fosi Audio reached out to me. I left them with my complaints for a few months, and they got back to me. They've revised some part of the Fosi K5 Pro to make it sound better on the USB inputs, but especially the optical and coaxial inputs, which were unusable before. So I would say that I definitely recommend the product in case anyone is buying it today. I think it sounds quite good. They also added new audio formats, including CD and DVD quality,
Lonestar
Huh, this is really interesting. Did they specify how it was improved? Different components / firmware / "tuning" (if that's even a thing)
I appreciate them listening to criticism but would love to hear how we as the customer could know which version we got?
Mine is from Dec 20th (Amazon Germany) and I'd really like to know if I got the improved version or not....
Pixol
One of the mainboards is a newer revision. I didn't take it apart any further. Like most Chinese companies, they kind of do a rolling release type of thing. It's probably near impossible to track down the changes without extensive knowledge. It did make the coaxial and optical inputs sound better to me, though.
warfront1
The real question is what even competes with this at a similar price range with better performance?
The idea seems nice that you start out with a basic headphone and microphone setup, and then you can expand out with the RCA out to another AMP.
Perhaps then you add on a dedicated ADC.
There seems to be a lot of innovation in these small portable USB DACs, but nearly all of the good ones don't include an ADC.
Ideally a quality small portable USB DAC that has an ADC and DAC, with an optional line-out mode.
You would be able to start out using it as DAC, ADC, and amp.
Then as you expand you would end up just using it as a line out DAC to a nice AMP.
Then you would have a separate ADC to handle your microphones.
Quexos
Does anyone know the difference between the K5 Pro and K5 (not pro)? I would be using it to replace onboard Realtek ALC1200 PC audio completely. Mic/Headphone and RCA out to amp connections are a must.
I am eyeballing these to pair with my Fosi V3, and mulling over if it would even be any better than just using my M-Audio M-Track Solo or staying with PC onboard. As in, is it just going to make my V3 sound worse or ~same as onboard?
What about a dirt cheap Syba Sonic SD-DAC63116? Seems like it might actually be just as good for $37.
Kimbrough Xu
The difference is we can not buy K5 anymore.
Quexos
Fair enough! They were still on Amazon back when I was 'shopping'. I went with the SybaSonic SD-DAC63118 for $36 in the end, and after one return+replacement (was disconnecting/dropping), I've been very pleased with it.
The weird curve and behavior of the EQ of the Fosi K5 Pro was a deal breaker for me, especially at ~2-3x the price.
Quexos
People are still buying this garbage.
Which garbage? The Fosi or the Syba I mentioned? There are not many alternatives with mic inputs, other than audio interfaces more for music production.
beefkabob
The Fosi that measures terribly. This is not a Syba thread.
Quexos
Yeah, I was eyeballing the Fosi K5 Pro pretty hard, until I read about the wonky EQ stage, and a few other sketchy results. It did not seem worth the $70 (maybe half that) at all, so I got the $35 Syba since it was so cheap. I figured worst case, it would still be usable on my backup PC or something, but it's actually not too shabby for the money.
The K5 non-pro is still available on Amazon too for ~20 bucks less than the Pro, but I have not been able to find a scrap of info on that, and presumably the K5 pro was created to fix/improve/replace the original K5, so I would not touch it without a good bit of info. I suspect it has/had some nasty problems.
