Genelec 1022B
Kvikk
Hi!
I have two Genelec 1022B.
Its not easy to find parts for them anymore so I was wondering if anyone have some tips on wich replacment speaker I can use for the bass element?
MAB
Portland, OR, USA
Hi!
Have you contacted Genelec regarding replacement woofer?
What happened to the woofers in your speakers?
K
Kvikk
I got them for free so I dont know their history other than that the woofer has been replaced once on both of them cause they was broken.
They got replaced with som unoriginal elements. I have asked Genelec and they said they did not have any replacement parts.
JustJones
Since they have been replaced, what's in them now? Genelec should be able to tell you specs of the woofer they used if nothing else.
Reactions: MAB
MAB
Portland, OR, USA
I wish I could help. I have no clue.
I would need the Thiele-Small parameters from Genelec to even begin finding a suitable replacement. I imagine one exists that could play well in the box size, with those ports, and whatever additional secret-sauce Genelec applies (like EQ). But Genelec would need to help you out here.
DVDdoug
It's generally best to use the exact same woofer because the cabinet is optimized for the particular Theile-Small parameters. This is especially critical with ported boxes. It's easy to badly mess-up a ported design whereas sealed boxes are somewhat less finicky.
You can "model" the performance by measuring/calculating (or estimting) cabinet volume and measuring the port dimensions, and then plugging the Thiele-Small parameters for various prospective drivers into a speaker design application. I've used WinISD (FREE!). There is also the possibility of modifying or plugging the port(s) and the software will tell you if that's better.
One unknown is if there is bass EQ built-in to further optimize the design, and that won't be optimized for a different driver and your speaker design software won't know about that.
The original (and replacement) woofer sensitivity is also unknown so the new replacement may be louder or quieter.
