Genelec 8351B Review (Studio Monitor)
preload
California
I didn't mean to imply that I have all the answers, just that a recording is distinct from the original performance. That said, I feel that it's reasonable to consider a speaker's performance as we would an amplifier's: the output signal should be exactly proportional to the input signal. If any changes are inaudible, that's probably close enough. Yes, I realize there are a million variables with directivity, where & how you measure, etc.; but it seems difficult to argue it's the wrong goal. And, yes, we have a long way to go.
I don't think anyone has all of the answers. That being said, the measurement of amplifier (and other solid state device) performance is essentially solved because the reproduction of the input signal (i.e. "recording") can be described through a suite of measurements (i.e. a 2-dimensional FR chart, various distortion measurements, various noise measurements, etc.), all of which we know how to interpret. Whereas, a 2-dimension FR chart does NOT fully describe the sound of a loudspeaker, not even close, because it radiates in all spherical directions and each sound vector interacts with the listening room (another variable), causing changes in phase and intensity. So no, you can't possibly consider an amplifier's performance in the same way as a speaker's performance.
Of course, that's not the full picture, as it ignores imaging/spatial characteristics, which is what I tried to address earlier. I'll grant this much: I don't believe there's a single radiation pattern which can accurately render the imaging of all recordings. But - sometimes - we can point to what works & what does not.
Here are a pair of @John Atkinson articles which do a better job at what I was trying to express. "Clowns" is a short one about imaging in the recording/performance context. "The Stereo Image" (1981!) is what I alluded to before - a longer examination of the imaging characteristics of different recording techniques. I have not reread this one yet, just skimmed enough to verify it's the article I remembered.
Thanks for the links to non-scientific magazine articles.
Descartes
Question to Amir would these be good for front speakers in a home theater setting crossed over at 80HZ with subs on the sides
Peluvius
They are excellent. I have mine crossed at 50Hz and the positioning of the sub/s will depend on your room.
Pearljam5000
Very unlikely, the 8351/8361 tweeter plays louder with lower distortion than the 8050B one.
Whats weird is they look exactly the same, plus Genelec never said anything about them but a lot about the other drivers
Sancus
I mean, just email them and ask if it matters to you.
Sancus
samysound
USA
What does the crossover have to do with THD in a sweep?
I was thinking the distortion might be higher if the tweeter has to play lower. moot point if the distortion is higher across the board though. I have not looked at the sweeps. poorly thought out comment on my part.
thewas
The sound so good here :)
Not very balanced tonally, also on the other hand placing the mics few inches close to the speakers would make almost any on-axis flatish loudspeaker sound good, but ignores the very important radiation behaviour (which is of course very good on those Genelecs).
Cadguy
I love that vintage Technics CD player. I wonder if it was available in North America?
Nehi
This is a review and detailed measurements of the Genelec 8351B powered monitors (speakers). It was purchased used by a member and kindly drop shipped to me for testing. They cost US $3,995 each.
The 8351 is a thee-way speakers with the bass drivers hidden beyond the front baffle:
Naturally the back panel allows for fair bit of configuration changes:
I reset the speaker to factory settings and left all the dip switches off as you see. I used analog XLR input for all measurements and listening tests.
I performed over 1000 measurement which resulted in error rate of around 1%.
Testing temperature was around 65 degrees F.
Reference axis for measurements was the center of the tweeter (by eye).
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Genelec 8351B Measurements
As usual we start with our spin frequency response measurements:
I expected flat on-axis response and we essentially get that. There is a tiny bit of deviation in lower frequencies. I checked with Genelec and they looked up the measurements and they are ± 0.5 dB in that region. They show it a bit flatter than I do but I don't think either one of us know whose measurements are more correct. :) Regardless, the deviation is tiny and your room would overwhelm it in practice.
Directivity plots show off-axis that is similar to on-axis as it should be with coaxial drivers. This is in turn reflected in early-window response and predicted one:
I don't have near-field driver responses for you since it was silly to try to measure them on a coaxial driver.
Directivity plots of almost textbook perfect:
Edit: forgot to post the distortion graphs before:
Finally waterfall shows a few resonances:
Genelec 8351B Listening Tests
Given the size of this speaker and interest in membership to use them in high-fi and home theater applications, I decided to listen to them using my main system in far field listening. From the first few seconds I knew the sound was right and in need of no adjustment other dialing out the one room mode I have around 105 Hz. Track after track has excellent sound with image coming out of a circular halo around the driver. This is what you get when the speaker is well designed and relies on decades of research on what good sound is. All of my reference tracks that were curated on another system like it translated and delighted just as well.
Dynamics and Competition with Revel Salon 2
There has been a lot of talk about how these two speakers compare in the forum. I find the conversion odd as we are comparing a bookshelf speaker to a full blown tower. Still, I decided to compare the two since I own the Salon 2.
The Salon 2 quickly showed its difference in taller image that was not so focused and centered as the Genelec. This of course could be an optical illusion of the Genelec pulling your eye toward its tweeter. Still, I stand by this observation. :) The other thing that stood out was that the highs were more prominent in Salon 2 bringing more realism to high frequency notes. The Genelec sounded subdued in this front. Perhaps there is some peaking in my Salon 2 (have not measured it yet).
Where one could not doubt a difference was the power capability and bass extension. On sub-bass heavy tracks the Genelec held its own at lower volume. As you turned up the level the bass driver started to make this annoying "furrrrring" sound on heavy bass notes. You could easily hear it if you stood on top of the speaker and listened through the slot on top. Turn up the volume a bit more and the red clipping indicator would come on.
The Salon 2 was in entirely different class. Powered with 1000 watts of amplification, it provided a level of belly shaking that the 8351B could not even dream about reproducing. And it would keep getting louder and louder with zero distortion and strain. It simply was not a fair fight even though the 8351B tries hard.
Overall, the Salon 2 provides that large, dynamic sound that a statement speaker needs to provide to fill a large space. The 8351 is for more intimate and more focused listening.
Both objectively and subjectively the Genelec 8351B delivers. Near perfection as far as tonality and dispersion is provided. Its power delivery is the best of any Genelec speaker I have tested so far and is almost beyond what you may need. In my case though, I am used to much larger and powerful systems and there, the 8351B was limiting especially with its bass slot noise. So I would not position it above its class.
Overall, it is my pleasure to put the Genelec 8351B on my recommended list.
Any donations are much appreciated using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150
They are an excellent pair for music production and mixing
don'ttrustauthority
This led me to check out the revel site as I want to hear 226 before buying but I can't find anyone with Revel speakers in the Sarasota area. The links all go to home theatre web sites that appear not to have home audio stores in the area.
Tangband
Sweden
I think those speculations about less good quality in Genelec 8351 bassdrivers are simply ridiculous.
A pro monitor thats used in a studio is always on, sometimes 14 hours in a row with endless looptrack of percussion and bass tracks playing at rather high spl.
Its completely the opposite what some of you are insinuating - a good and expensive pro monitor is made to last .
…and if the quality were less in some areas, wouldnt you have heard about it in pro-forums ?
The comparison with Behringer is also ridiculous. Behringer are cheap, good sounding monitors with no focus in quality at all - they have a very bad reputation because of that in the pro-world.
As a former DIY:er , it was an ear-opener to hear those 83xx monitors and also doing extensive measurements on the 8330 .
They are really as superior as Amirms measurement shows. Using a digital input signal feeding the dsp crossover directly, makes the sound even more clear than other alternatives in the hifi market - in my opinion.
