Genelecs for home audio?
M
ManFromKerala
Genelec is polarising :), that much I have understood.
I shall try to get a sense of SPL and then start from there. Thank you all.
I will report back with what I ended up with finally
Cheers
voodooless
Netherlands
If you already have a current system, install some SPL measurement apps on your phone. They are not perfect but give a rough estimate. On an iPhone, the measurements should be more accurate on average, because the limited range of models makes it easier to calibrate them.
Just look at what levels you're comfortable will, what you find loud. Also, try various types of music. Now the values these apps show are usually averages. You'll need to add 10 to 15 dB to get to the maximum SPL you'd like your speakers to have at your listening position.
srrxr71
Go to St. Marks road in Bangalore and audition then. One of 4 genelec experience centers in the world. When I heard the prices I felt like having a business to save on VAT would be very helpful.
Your jaw will drop when you hear them.
Danaxus
Greece
Is it practical to use non-SAM Genelecs (i.e. the 80XX series), as surrounds? If so, the OP could find an older pair of Genelecs (maybe even the 8020's for < $500), see how they hold up as his mains, and if they don't, he can relegate them to side or rear surrounds (where they'd be pretty kick-ass!).
The only thing is, I don't know if it's possible to remote control their volume, or manage their volume through the AVR. Anyone here have any insights into this?
NiagaraPete
The Avr would need line outs, preferably balanced.
NeoZs99
The issue is actually finding used Genelec. You could very much be waiting years, and I can't imagine they are any more frequent in India as they are in other areas despite the higher population. Over 3k you are in brand new Neumann KH 310/150 territory which I think I'd prefer over a non-coaxial Genelec.
I second this. Try the Neumann KH310 maybe..?
srrxr71
I used my 8010s with an apogee duet which can control volume. Finding one used should be easy especially the last generation one.
