- Joined
- Oct 25, 2019
- Messages
- 11,137
- Likes
- 14,806
Enog2 Pro had the ability to switch gain level by holding down the button for 3 seconds.
I could not find official Enog2 Pro specifications, but I am guessing Low gain = 2.5v and High gain = 4v (4.3v according to XLR measurements).
And according to Geshelli the JNOG DAC has 3 gain level settings (low/med/high).
As does the J2- same set up- see the Manual https://img1.wsimg.com/blobby/go/52b28b80-5994-41e3-9b66-4d188ae2874f/downloads/jnog2 user manual.pdf?ver=1621055624915
@Geshelli - you might want to update the webpage to clarify 2.5V isnt Max XLR output- I think youve just shown the measurements at either low or med gain (whichever 2.5V is)
Holding input button again toggles output level @SBrob @Drengur @Swtoby @blagadies @dseong @Veri
