Got new tv with EARC, need help deciding AVR with some restrictions.
Chrispy
PNW
Wasn't the "issue" with downconverting feeding it multich pcm when only 2ch had content? Is that a real world situation?
S
Scubaduderon
Not exactly sure. Ive been told it won't happen to me when I feed 2 channel audio via toslink.
Chrispy
PNW
Yes I would only expect the issue if feeding it 5/7 channels with only 2 having content....if I remember the issue correctly....
S
Scubaduderon
Yeah, kinda obscure but to a newb like me, I don't know hoe to weigh the issues...
polmuaddib
No, the bug happens when you assign only two front speakers to your AVR configuration. Let's say you only have two physical speakers and that is your configuration in an AVR. Then you have rising noise and distortion (not sure if both, but one for sure).
But if, still having only two speakers, you assign all the 11 speakers in an AVR, even though you don't physically connect them, then you will not have the bug. You can still play 2ch content fine, but in that case it would be hard to downmix mch content to 2ch, if not impossible. Of course, it is better to connect all the speakers you have.
So the problem that remains is if you want to play mch content on two speaker configuration. But, why would you do that??? Then go buy stereo integrated amp.
S
Scubaduderon
So the problem that remains is if you want to play mch content on two speaker configuration. But, why would you do that??? Then go buy stereo integrated amp.[/QUOT
Thank you for your explanation. The reason I need to know about 2 channel is about 20% of the time I listen to the RL channels for stereo music off of my AVR. I dont have enough rooms to have seperate systems, so I use the living/dining room for HT and stereo listening. I guess I'm after the best of both worlds, without breaking the bank.
Chrispy
PNW
Just use the stereo mode on the avr when using 2ch content.....or upmix it to multich if you desire. You're in control....
polmuaddib
Right. Or Direct mode or Pure Direct mode. When you have 2 channel content and you speaker configuration is 11.1 or 5.1, it should play only 2 channels as intended. In stereo mode, depending on the configuration, subwooofer might be involved, if you set your front speakers to small.
So you can enjoy room correction and all the goodies for 2 channel or multichannel. No need for separate system.
Webninja
Los Angeles
If I’m reading the original post correctly, wouldn’t you need the Denon 8500 to have flexible external amp assignments?
I believe that’s the only model that you can do more than just L/R, or all external. Basically if you want the AVR to handle some of the amplification and external for the others (aside from only L/R) then the 8500 is the go to.
S
Scubaduderon
Thank you for helping me. I thought about the 8500 and I agree. With all my different old school euipment hanging off the AVR preamps, I'll be wasting active internal amps that I could simply turn off with the 8500. But for me the 8500 loses out in 2 ways. 1, it doesn't have the latest video processing with the 8K stuff etc, and 2, it's too expensive...
